    [REQUEST] Simple bone structure
    17 Posts 10 Posters 2.5k Views 10 Watching
    • tt_suT Offline
      tt_su
      Ohh... this is an interesting thread!
      • sdmitchS Offline
        sdmitch
        Well that is certainly a lot to think about. I recently did simple hinged components on the xy plane but this is a whole different animal. Will give it some thought but don't hold your breath.
        http://sdmitch.blogspot.com/
        • silvershadowS Offline
          silvershadow
          πŸ˜ƒ its just some food for thought for future development πŸ˜ƒ
          • ely862meE Offline
            ely862me
            Can't SketchyPhysics be hacked to support this? For example moving an arm or so. You do it with the move and rotate tools, but you need the hinges to retain the structure in one piece. Of course everything without gravity so it won't just hang there.
            Elisei (sketchupper)
            Come and See EliseiDesign
            • PixeroP Offline
              Pixero
              Interesting.
              There is a chapter in Automatic SketchUp that touches this.
              Page 288 and forward.
              http://rhin.crai.archi.fr/rld/pdf/Automatic_SketchUp.pdf
              • duanekempD Offline
                duanekemp
                I have a current project that desired keyframe animation with finger movement of a hand on a product design. After research, I purchased the Leap Motion Capture USB device and soft to record the .bvh data. Unfortunately, I couldn't get a response from Leap about technical issues in time, so abandoned the idea for a keyframe animation without the finger manipulation (simple fixed hand animation from one point to another as a consolation).
                However, I was dreaming during this whole experience that there was a way to import into SU the Zbrush bone structure or something similar to help manipulate a high poly SU model. Since, I've been curious if SU being 64 bit now has others pondering or working on solutions for bone structure, .bvh data recording and model animations.
                This thread is more than interesting for this reason... Silvershadow, thanks for introducing this subject. I'm following with anticipation.
                Duane Kemp
                Kemp Productions
                Puidoux, Switzerland
                Gallery:
                https://duanekemp.artstation.com/
                  http://code.google.com/p/sketchup-skel/ πŸ˜‰
                  • F Offline
                    faust07
                    bones ... πŸ˜‰
                    Sketchy Physics models from 3D-warehouse
                    "Physics-bones" from 3D-warehouse
                    walking model
                      duanekemp
                      Pilou and Faust, thank you for responding.
                      I was hoping to get more time with Brekel Kinect with .bvh support with Leap Motion Capture and use Simfonia animation tools to import the .bvh data into SU. But... dang.... fairly expensive tool, that last one and didn't seem like it would be easy to work with a high poly model.
                      Are there ANY other options than what I've just mentioned than the stop motion animation process described in the videos above?
                      The Keyframe Animation Plugin seemed like it was going to take about the same amount of time with much more control of the model than the path I had originally chosen.
                      http://www.simfonia.fr/SAT/index.php?page=compare%26amp;PHPSESSID=a6odgrvpk88nu6ghbt1oohrn37
                      Duane Kemp
                      Kemp Productions
                      Gallery:
                        driven
                        @Daune
                        Chris Glasiers version/update of the same code is possibly a better starting point...
                        I linked to it earlier in this thread, third or fourth post...
                        • BoxB Offline
                          The Snap Connector tool from Cadman might be of some use in all this.
                          https://extensions.sketchup.com/en/content/snap-connector
                            duanekemp
                            Pilou, I will have to try this and see how this works... and if I can get it to work as I hope it might. Again... thank you for the link.
                            https://code.google.com/p/sketchup-skel/
                            Duane Kemp
                            Kemp Productions
                            Gallery:
