    CFileException 3 - ERROR!
    25 Posts 12 Posters 29.9k Views 12 Watching
      slbaumgartner
      @john2 said:
      I fail to understand what is causing this. And I am not running sketchup on network. But I am facing a problem. I have to enable my wi-fi everytime to use Sketchup 2015 in order to bypass licensing error problem. I just enable my wifi adaptor, and not connect to anywhere. Is that causing this problem?
      I have noticed, Su guys have made a useless "enable your laptop's wifi adaptor" so that sketchup starts easily. Else, it won't start.
      The new licensing scheme employed in SU 2015 uses your network adapter's hardware address to identify the computer. This information is not available when the network adapter is disabled, so SU's license check fails.
      Do you momentarily turn on WiFi so SU will start and then turn it off again? I wonder if that could induce the invalid path error (don't know, just guessing...)?
      • KrisidiousK
        Krisidious
        I'm not on wifi and have not turned off my network card. The error came again after a few more hours work and after changing to administrator use only.
        By: Kristoff Rand
        • ely862meE
          ely862me
          If you have the SUSOLID extension, try to remove it and see if the problem occurs that bad again.
          Elisei (sketchupper)
          Come and See EliseiDesign
          • KrisidiousK
            Krisidious
            I have Pro... So no need for Solid tools.
            By: Kristoff Rand
            • ely862meE
              ely862me
              It was pretty bad for me until I removed it, and now it happened just for once or twice. When it happens I try to Save as and then Save again. Sometimes it's related with the fix your model thing and the autosave.
              • KrisidiousK
                Krisidious
                Yeah when the error happens I click ok and it makes a backup file with every click of ok and the error never goes away... While I'm working I have the folder open in another window, I can see the autosave file. When the error happens the autosave file disappears. i do have check for errors and fix automatically checked. I wonder if whatever issue SUSolids has, if another plugin has it as well?
                By: Kristoff Rand
                • ely862meE
                  ely862me
                  It might be possible to be another plugin. I had to find it the hard way: I removed groups of 3 or 4 helped by Scf Plugin manager until the error didn't occurred anymore. Then tested those last 3 and there it was.
                  The idea is to make the error repeatable. In my case, I set the Autosave to 1 minute and I was playing with move tool with the edges from a subdivided mesh. It worked every time. Exactly when the Autosave was kicking if I played with an edge the error occurred.
                  • H
                    hahiru
                    @krisidious said:
                    Just got one of these with 2015... no autosaves, 10 skb's none of any use. lost hours of work. HATE!
                    You should check this 123
                    I have setup windows and sketchup2015 overwrite the old.So my profile cause this problem.
                    Some one said this program need microsoft.NET Framework 4.0,try install it.
                    • KrisidiousK
                      Krisidious
                      still losing time on this...
                      moved file to desktop and set reset autosave and backup. (so it would be on main harddrive)
                      made sure program ran as admin. no help.
                      seems to be when I move geometry manually...
                      I think it's a plugin doing it. I'm getting it every 20 minutes or so. I lose everything back to open. autosave is deleted as error happens and backups start being made with every click of the ok button. the backups are of the last open. I saved myself last round by making save as copies.
                      By: Kristoff Rand
                      • KrisidiousK
                        Krisidious
                        you can see the crazy geometry move as the error happened. also happened later with pushpull.
                        By: Kristoff Rand
                        • B
                          Bill Mak
                          hey Krisidious
                          I was just wondering if u finally found the solution to the problem
                          everything u described is happening with me exactly the same!!!
                          • P
                            paulsov123
                            I don't know if we have the same problem, base on what I have experienced, it also appears the moment I click Save As or Ctrl S..
                            What I did was I access Windows defender, click Settings, Click the Virus & threat protection settings, look for the Controlled folder access and turn it off..
                            Maybe it will solve your problem..
                            • 2 / 2
