    Flatten and Rename/renumber scenes Plugin for Sketchup 2015
    18 Posts 5 Posters 1.6k Views 5 Watching
    • onzkiO
      onzki
      Hi everyone,
      Back in version 8, I have 2 plugins that successfully worked well.
      1. Flatten- Just one command and it flattens the newly imported CAD plan.
      2. Rename/Renumber scene- (scene_rename.rb) Very useful in keeping scenes in order, it sorts the numbering of scenes.
      Unfortunately, I didn't find one that works with Sketchup 2015, Any suggestions?
      Thanks! πŸ˜„
      [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
      • Bob JamesB
        Bob James
        Why not PM Todd Burch and see if he'll update the Smustard 2007 version?
        • onzkiO
          onzki
          Thanks! will do..
          • sdmitchS
            sdmitch
            @onzki said:
            Hi everyone,
            Thanks! πŸ˜„
            Just a guess but test this on a sample model to see if satisfies both needs.
            You can execute it by copying and pasting in the Ruby Console.
            mod = Sketchup.active_model
            ent = mod.active_entities
            sel = mod.selection
            #Flatten to XY plane
            vers = [];vecs = []
            ent.grep(Sketchup;;Edge).each{|e|vers<<e.vertices}
            vers.flatten!;vers.uniq!
            vers.each{|v|vecs<<Geom;;Vector3d.new(0,0,-v.position.z)}
            ent.transform_by_vectors(vers,vecs)
            #Rename Scenes
            pages = mod.pages
            new_name = 'Scene 0'
            for page in pages
             new_name = new_name.next
             page.name = new_name
            http://sdmitch.blogspot.com/
            • CadFatherC
              CadFather
              both working flawless. on flatten, need to explode any curves if present, but amazing lean code! πŸ‘
              would be fantastic if only the visible lines from a top view were flattened - basically making 2d shapes for cad drawings! 😲
              • sdmitchS
                sdmitch
                "lean" is my middle name!
                "only the visible lines from a top view"?
                • CadFatherC
                  CadFather
                  ...my own middle name has been 'chabbo' for quite sometime now! 😎
                  yes, only the lines visible from above.
                  • sdmitchS
                    sdmitch
                    What about lines that are partially visible?
                    I assume any vertical line would not be visible.
                    • CadFatherC
                      CadFather
                      yes, no vertical lines. i'm thinking of a chair, one needs the profile lines and the main visible ones, as long as they're not vertical.
                      (though now you make me think it'd be fab having it flatten on the red or green plane too (!), for which case verticals are ok but not horizontals) 😲
                      • sdmitchS
                        sdmitch
                        THE PLOT THICKENS!!!!!!!!!!!!!!
                        So simple. All we need is an option for Top, Front, or Right view.
                        Some horizontals would be OK if they are perpendicular to the axis of choice.
                        • CadFatherC
                          CadFather
                          the plot is as thick as it gets!!! πŸ˜†
                          • F
                            faust07
                            I will not slow your enthusiasm, but I think TIG has a plugin for it: CADup V1.2a. Whether it is suitable for the newer versions of SketchUp, don't know ...
                            • sdmitchS
                              sdmitch
                              You are correct. http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=31895%26amp;hilit=Flatten
                              • CadFatherC
                                CadFather
                                ok thanks, i'll check it out, (had to be TIG! πŸ˜† )
                                EDIT. actually i do know that script and it is very good, though it only works if you have workplane installed.
                                • sdmitchS
                                  sdmitch
                                  The WorkPlane plugin is really not required. All you need is a group named WorkPlane which contains a single face that defines the desired plane. Then you can comment out or delete line 51 "require WorkPlane.rb".
                                  • CadFatherC
                                    CadFather
                                    great, that's what i'll do then. makes it for a slightly faster job as well.
                                    just as i was getting chaffed about the all new flatten plugin...the idea of the visible lines was a good one though!
                                    • sdmitchS
                                      sdmitch
                                      Maybe I have an old version of Flatten To Plane but it seems to have a problem with embedded components.
                                      Post a model,v2014, with a sample or two what you would want the plugin to flatten to visible lines only.
                                      • CadFatherC
                                        CadFather
                                        i was thinking of these situations (attached file). of course to view with hidden geometry on.
                                        for a human figure, from 3000 edges we go up to 20000 when flat.
                                        flattens.zip
