    Flatten and Rename/renumber scenes Plugin for Sketchup 2015
    18 Posts 5 Posters 1.5k Views 5 Watching
    • CadFatherC Offline
      CadFather
      both working flawless. on flatten, need to explode any curves if present, but amazing lean code! πŸ‘
      would be fantastic if only the visible lines from a top view were flattened - basically making 2d shapes for cad drawings! 😲
      • sdmitchS Offline
        sdmitch
        "lean" is my middle name!
        "only the visible lines from a top view"?
        http://sdmitch.blogspot.com/
          CadFather
          ...my own middle name has been 'chabbo' for quite sometime now! 😎
          yes, only the lines visible from above.
          • sdmitchS Offline
            sdmitch
            What about lines that are partially visible?
            I assume any vertical line would not be visible.
              CadFather
              yes, no vertical lines. i'm thinking of a chair, one needs the profile lines and the main visible ones, as long as they're not vertical.
              (though now you make me think it'd be fab having it flatten on the red or green plane too (!), for which case verticals are ok but not horizontals) 😲
              • sdmitchS Offline
                sdmitch
                THE PLOT THICKENS!!!!!!!!!!!!!!
                So simple. All we need is an option for Top, Front, or Right view.
                Some horizontals would be OK if they are perpendicular to the axis of choice.
                  CadFather
                  the plot is as thick as it gets!!! πŸ˜†
                  • F Offline
                    faust07
                    I will not slow your enthusiasm, but I think TIG has a plugin for it: CADup V1.2a. Whether it is suitable for the newer versions of SketchUp, don't know ...
                    • sdmitchS Offline
                      sdmitch
                      You are correct. http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=31895%26amp;hilit=Flatten
                        CadFather
                        ok thanks, i'll check it out, (had to be TIG! πŸ˜† )
                        EDIT. actually i do know that script and it is very good, though it only works if you have workplane installed.
                        • sdmitchS Offline
                          sdmitch
                          The WorkPlane plugin is really not required. All you need is a group named WorkPlane which contains a single face that defines the desired plane. Then you can comment out or delete line 51 "require WorkPlane.rb".
                            CadFather
                            great, that's what i'll do then. makes it for a slightly faster job as well.
                            just as i was getting chaffed about the all new flatten plugin...the idea of the visible lines was a good one though!
                            • sdmitchS Offline
                              sdmitch
                              Maybe I have an old version of Flatten To Plane but it seems to have a problem with embedded components.
                              Post a model,v2014, with a sample or two what you would want the plugin to flatten to visible lines only.
                                CadFather
                                i was thinking of these situations (attached file). of course to view with hidden geometry on.
                                for a human figure, from 3000 edges we go up to 20000 when flat.
                                flattens.zip
