    Flatten and Rename/renumber scenes Plugin for Sketchup 2015
    18 Posts 5 Posters 1.6k Views 5 Watching
    • sdmitchS
      sdmitch
      @cadfather said:
      both working flawless. on flatten, need to explode any curves if present, but amazing lean code! πŸ‘
      would be fantastic if only the visible lines from a top view were flattened - basically making 2d shapes for cad drawings! 😲
      "lean" is my middle name!
      "only the visible lines from a top view"?
      http://sdmitch.blogspot.com/
      • CadFatherC
        CadFather
        ...my own middle name has been 'chabbo' for quite sometime now! 😎
        yes, only the lines visible from above.
        • sdmitchS
          sdmitch
          What about lines that are partially visible?
          I assume any vertical line would not be visible.
          • CadFatherC
            CadFather
            yes, no vertical lines. i'm thinking of a chair, one needs the profile lines and the main visible ones, as long as they're not vertical.
            (though now you make me think it'd be fab having it flatten on the red or green plane too (!), for which case verticals are ok but not horizontals) 😲
            • sdmitchS
              sdmitch
              THE PLOT THICKENS!!!!!!!!!!!!!!
              So simple. All we need is an option for Top, Front, or Right view.
              Some horizontals would be OK if they are perpendicular to the axis of choice.
              • CadFatherC
                CadFather
                the plot is as thick as it gets!!! πŸ˜†
                • F
                  faust07
                  I will not slow your enthusiasm, but I think TIG has a plugin for it: CADup V1.2a. Whether it is suitable for the newer versions of SketchUp, don't know ...
                  • sdmitchS
                    sdmitch
                    You are correct. http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=31895%26amp;hilit=Flatten
                    • CadFatherC
                      CadFather
                      ok thanks, i'll check it out, (had to be TIG! πŸ˜† )
                      EDIT. actually i do know that script and it is very good, though it only works if you have workplane installed.
                      • sdmitchS
                        sdmitch
                        The WorkPlane plugin is really not required. All you need is a group named WorkPlane which contains a single face that defines the desired plane. Then you can comment out or delete line 51 "require WorkPlane.rb".
                        • CadFatherC
                          CadFather
                          great, that's what i'll do then. makes it for a slightly faster job as well.
                          just as i was getting chaffed about the all new flatten plugin...the idea of the visible lines was a good one though!
                          • sdmitchS
                            sdmitch
                            Maybe I have an old version of Flatten To Plane but it seems to have a problem with embedded components.
                            Post a model,v2014, with a sample or two what you would want the plugin to flatten to visible lines only.
                            • CadFatherC
                              CadFather
                              i was thinking of these situations (attached file). of course to view with hidden geometry on.
                              for a human figure, from 3000 edges we go up to 20000 when flat.
                              flattens.zip
