    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 82.7k Views 40 Watching
    • panixiaP Offline
      panixia
      @rv1974 said:
      P.S. Attached animation shows side-by-side PB1 (O.K.) vs PB2(defected) behavior.
      Maybe you could try to uninstall older version and see what appens?
      that older dialogbox arrangement is better IMHO because is less screnspace-consuming and the assembly editor is somehow cumbersome too.. this is pretty hard to handle on a laptop.. at least if not a more compact arrangement, would be nice to have some sliders to scroll when the windows are verticlally resized so that could be possible to stack them one on top of the other..
      another thing i noticed is that PB is breaking the curve of profiles created by me extruding faceted surfaces.. below you can see the very same profile used with native followme produces smooth surfaces as expected.. if i "stamp" the profile and check the curves they are actually exploded.
      it is possible to preserve the curves/smoothing? it could be also better if diagonals were set respect ThomTom's quadface convention like other sweeping and lofting tools such extrude edges by rails or curviloft already do.
      aside that it looks a very impressive and robust extension, in aprticular the assembly builder is GREAT tahnk you for the generous and long trial period.
      edit- i encountered other problems PB sometimes refuses t work in updating assembly propertys or building assembly along path this is another error i get. it needs to restart sketchup quite often to fix this..
      bs:1694:in build_rails' c:/users/panixia/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/dm_profilebuilder2/assembly.rbs:1665:in draw'
      c:/users/panixia/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/dm_profilebuilder2/assembly.rbs:705:in build_fence' c:/users/panixia/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/dm_profilebuilder2/assembly.rbs:79:in block in initialize'
      SketchUp:1:in `call'
      • JQLJ Offline
        JQL
        @rv1974 said:
        @JQL: I attached the animated gif. All needed buttons were pressed, believe me.
        Sorry rv1974. I hadn't noticed it was a gif and you clearly know what you're doing. Did you try uninstalling PB1? Maybe there's a conflict there.
        www.casca.pt
        Visit us on facebook!
          AcesHigh
          since this is now the official thread, bringing here the question I made on the other one:
          @whaat said:
          Hi Aces,
          That's a difficult one to do with the plugin. In general, it is designed for profiles to be used to connect the components. You should be able to create a polyline profile for the wire mesh instead of a component but it won't be as realistic as what you are trying to achieve. Thanks for the feedback!
          Whaat, wouldn´t you be able to achieve that by using code similar to FredoScale's Planar Shearing? It´s easy to think of other things that would benefit from it, like electricity poles connected by electrical wires (the wires would be an arc... planar shearing them when the poles have different heights would be better looking than rotating the arcs)
          • panixiaP Offline
            panixia
            maybe you could be also interested in this cool pugin.. i find it more specific for that kind of stuff you're saying.. 👍
            404 Not Found
            (sketchucation.com)
            • KrisidiousK Offline
              Krisidious
              LMAO...
              By: Kristoff Rand
              • W Offline
                Whaat
                @srx said:
                Now we need points, for example smart parametric openings cutting the lines(walls), and changing with them. Is it possible?
                Hopefully someday...
                • W Offline
                  Whaat
                  @panixia said:
                  that's very cool!
                  btw looks like something is going wrong here.. 😲
                  [attachment=1:3z3sosk3]<!-- ia1 -->profile error.jpg<!-- ia1 -->[/attachment:3z3sosk3]
                  edit-i found another problem where the "build along path" refuse to work with a custom drawn profile..
                  it works in the simple/pen "build" mode but not with preselected path here is the error in the console.. in case it may help..
                  rbs:575:in collect' c:/users/panixia/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/dm_profilebuilder2/pathtools.rbs:575:in points'
                  c:/users/panixia/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/dm_profilebuilder2/pathtools.rbs:77:in get_selected_path' c:/users/panixia/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/dm_profilebuilder2/profilebuilder.rbs:788:in block in initialize'
                  [attachment=0:3z3sosk3]<!-- ia0 -->profile error 2.jpg<!-- ia0 -->[/attachment:3z3sosk3]
                  Hi Panixia,
                  Thank you for your feedback! If you are able to reproduce any of these errors on a consistent basis, please let me know the detailed steps so I can fix these issues.
                  Dale
                  • W Offline
                    Whaat
                    @burkhard said:
                    Just bought. Now I need this on my training Laptop as well.
                    Does it work with copy and paste in 2015 or do you offer another way?
                    Buy another copy? 👊
                    Seems the trial version could not be activated by a license now.
                    Hi Burkhard, if you hare having problems activating the license, please contact SketchUp Extension Warehouse support or check here:
                    Site Not Found - Discourse
                    (forums.sketchup.com)
                    • W Offline
                      Whaat
                      @rv1974 said:
                      Just purchased. Great script, Dale. I suppose it'd be even greater if it'd start to work. 😕
                      Any ideas how to fix it?
                      P.P.S. The Typical fragment from Ruby console:
                      Error: #<NoMethodError: undefined method parent' for nil:NilClass> C:/Users/XXX/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/smartdrop.rb:25:in definition'
                      c:/users/XXX/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/dm_profilebuilder2/profilemember.rbs:58:in initialize' c:/users/XXX/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/dm_profilebuilder2/profilemember.rbs:28:in new'
                      c:/users/XXX/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/dm_profilebuilder2/profilemember.rbs:28:in add' c:/users/XXX/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/dm_profilebuilder2/profilebuilder.rbs:1758:in place_member'
                      c:/users/XXX/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/dm_profilebuilder2/profilebuilder.rbs:1476:in `onLButtonDown'
                      Hello sir,
                      Looks like an issue with your Smartdrop plugin. Try disabling that extension, restart SketchUp and trying PB2 again.
                      • W Offline
                        Whaat
                        Thanks for the report again,
                        Unfortunately, the beginning part of the error message has been cut off. Can you re-post this with the full error message?
                        • W Offline
                          Whaat
                          @whaat said:
                          Hi Aces,
                          If I keep getting requests about this, I will definitely consider it, thanks!
                            AcesHigh
                            @whaat said:
                            @whaat said:
                            Hi Aces,
                            no, thank you for considering the possibility of considering it 😄
                            one more question... will there be a user manual?
                            and maybe I am missing something, but is there a way to update the built structure in case you decide to change some parameters, or we have to delete and build it again?
                              rv1974
                              OK I'll try it in 2 days. Thank you for timely support.
                              BTW The icons made with a great taste!
                              • panixiaP Offline
                                panixia
                                sorry i deleted the test file.. my bad.. maybe next time the error will pop i'll send a better report or upload you the model to examinate 👍
                                • dereiD Offline
                                  derei
                                  I tried to buy the plugin, but the promotional price doesn't seem so promotional after all... especially that I have bought the first version few years ago.
                                  First of all, PayPal not supported... second, what is that "tax" applied over the declared price? And if there is a tax, why the price isn't displayed WITH the tax, because I am not interested how much money the developer (or the website) gets from this, but rather how much I have to pay. Adding extra fees on the way is just not a fair way to do it. My opinion.
                                  DESIGNER AND ARTIST DEREI.UK
                                    Krisidious
                                    [attachment=0:3eptudkj]<!-- ia0 -->2015-03-15_144725.png<!-- ia0 -->[/attachment:3eptudkj]
                                    These are probably not choices of the Developer, but the seller. Taxes. The government will have their share.
                                    By: Kristoff Rand
                                    • jujuJ Offline
                                      juju
                                      I think the point is that the price advertised should include taxes.
                                      Paypal not supported? That's unfortunate.
                                      Why not have it available on Smustard.com as well?
                                      • SektaS Offline
                                        Sekta
                                        I was a big fan and daily user of PB1, PB2 is just awesome. Purchased it couple of days ago and really like the new interface. The simple 2D profile stamp sounds simple but invaluable for 2D drafting. You can either mock up your details in SU or simply cut and past the profile direct in LO and do them there.
                                        I have been trying to build my own assemblies as I see these being invaluable in the work I do. When you create your components and profiles and assemble them, is there a trick how to do this so you don't have to spend alot of time aligning the profiles and components in the assembly. Mine seem to end up all over the show.
                                        Great work Whaat, love this plugin.
                                        Sekta
                                          rv1974
                                          I wish the Author will overcome (in the near future) the biggest limitation:
                                          only connected edges are accepted as profile path.
                                          NB: Dudes leaf through the Help pages. This is really thermo-nuclear power plugin!
                                            AcesHigh
                                            404 Not Found
                                            (sketchucation.com)
                                            thanks Panixia. I know that plugin. It´s better for joining a few electricity poles. But what if you want to place 100 poles with the wires?
                                            • 11
                                            • 2 / 11
