    Stairs with spiral section. How?
    10 Posts 5 Posters 936 Views 5 Watching
      CalypsoArt
      Hi all, I'm at a loss here on this piece. I need to make a stair that has a straight run and then a spiral bit. The carriage is about 1' and follows the curve. Any one suggest a method to accomplish this? Attached is a bad rough of what I'm trying to do.
      Group_142.skp
        TECHDAVE02
        please back save
        star.skp
        • S ShepherdS Offline
          S Shepherd
          I'm not sure exactly what you are looking for but this is my first guess.
          Close?
          Shep
            CalypsoArt
            Yes! That's it. I have to make several versions. How did you do it? Plugins?
            • gillesG Offline
              gilles
              Radial bend in FredoScale:
              http://sketchucation.com/forums/viewtopic.php?p=144180#p144180
              Click to see animation
                TECHDAVE02
                As gilles said fred06 scale
                stair x 5.skp
                  CalypsoArt
                  Thanks, I've used that plugin before, but never needed my bends to be at specific places. Obviously I need to look at the tutorials again. Last question. If the stairs are built with details--balustrades, handrail etc--will those bend as well?
                    S Shepherd
                    My previous post was done quickly with solid tools, curviloft and joint push/pull.
                    This can be done with Make and without plugins. It just takes some hand stiching.
                    Shep
                      CalypsoArt
                      Using Fredo's plugin. However I get this hole after the bend.
                      stair test.skp
                      • ely862meE Offline
                        ely862me
                        Just draw that line and the surface will close.
                        Elisei (sketchupper)
                        Come and See EliseiDesign
