    [Plugin] ShadowProjector
    129 Posts 36 Posters 107.9k Views 36 Watching
      max8167
      Your plugin it's very useful
      Do you think it is possible to change script in order to have result during a time period and not at a given time? Have you avenues of work and reflection?
      Thank you for advance
        @max8167 said:
        Just do several shadows over a series of scenes with different times ?
        It cannot cope with reflections, if that's what you meant ??
          Updated version v1.4 is now available.
          It has an additional option that can be typed into the Ruby Console:
          TIG.shadowReport **true**
          to choose a file and write the shadow report directly into it...
          http://sketchucation.com/pluginstore?pln=TIG_shadowProjector
            barney_and_ted
            Hello TIG,
            Your plugin is very useful πŸ‘
            The face name is automatically create in the report ! Is it possible to change it ? In order to have more convenient name.
            Thank you
              djh
              Dear TIG,
              Your plugin looks like just what I need - to export vector (dwg or dxf) with shadows. I am drawing technical illustrations with fine lines and shadows. When I export them as a jpg or tiff and shrink them down, the lines get broken and don't print well. But, I can't figure out how to use your plugin. I keep getting this message even when I select a face. "You must Pre Select at least ONE Suitably Oriented Face!" I haven' projected a shadow yet. I even tried with some very simple models, but...
              Can you please help me?
              DJH
                driven
                make sure the 'face' is the front face...
                  djh
                  Thank you very much, Driven and TIG. Also, I exploded all the components and groups. It works wonderfully.
                    You don't need to explode everything.
                    But you do need to select the face[s] to receive the shadow outlines.
                    This means they do need to be in the same context, but then you could edit the container and select the face ?
                      djh
                      This means they do need to be in the same context, but then you could edit the container and select the face ?[/quote]
                      What does it mean "in the same context"?
                        djh
                        Having problems, even when I redrew the model as simply as possible.
                        Shadow.skp
                          Thanks ofr the example SKP.
                          I do agree that it fails.
                          But the info I get from the Ruby Console is helpful to see what is wrong.
                          I'll look at how it might be recoded to resolve the issue.
                          Incidentally, you model contains some reversed faces inside the grouped 'walls' and several bits of hidden geometry [View > Hidden Geometry > ON] around the tops/ends of some walls.
                          Although they shouldn't cause issues it's good practice to tidy your model as you go.
                          With them gone it still fails, so they're not the cause of the issue...
                          I will fix it. πŸ˜•
                          Watch for updates/announcements...
                            Here's v1.5 http://sketchucation.com/pluginstore?pln=TIG_shadowProjector It fixes a problem which resulted from instances [groups/components] sat directly 'on' a shaded-face, and sometimes not casting a shadow below them.
                            It should now be more robust and cope with raw geometry, groups and components placed directly on top of the shaded-face.
                            It works properly with @djh's example SKP ! πŸ˜„
                              Thanks for the update. I'm still getting unexpected results. See the attached screen shot. The edges of the projected "shadow" are 500 meters long and extend down below the face on the ground plane and away from the sun.
                                Thanks Dave, I too have seem some issues and I'm working on a fix... πŸ˜’
                                The face should be 1km long NOT 500m !! πŸ˜‰
                                  Half is better than none.
                                    djh
                                    TIG, thanks for the advice to clean up the model.
                                    I'm sorry, I still got the same results. I don't know how you were able to do it with the same model. Also, you mentioned before, "This means they do need to be in the same context, but then you could edit the container and select the face?" What does it mean "in the same context"?
                                        Here's v2.0 http://sketchucation.com/pluginstore?pln=TIG_shadowProjector
                                        It is completely rewritten to be faster ad more robust...
                                          Here's v3.0 http://sketchucation.com/pluginstore?pln=TIG_shadowProjector Along with ignoring Hidden faces/objects and those assigned OFF Layers, it now respects transparent faces [<70% opacity] which won't cast shadows, and similarly faces with the default-material faces within a container that itself has a transparent material and which doesn't then cast a shadow etc.
                                          Objects with cast/receive shadows 'unchecked' settings are now fully respected in the shadow analysis.
                                          Faces which shade themselves [because they face away from the sun] are automatically assigned 100% shading with no further analysis...
                                          A glitch with report writing if type was 'lines' is now resolved.
                                            Latest version installed. Get this in console when trying to run the tool.
                                            Error: #<NoMethodError: undefined methodeach' for nil:NilClass>
                                            C:/Users/Dave/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TIG-ShadowProjector/TIG-ShadowProjector_Code.rb:127:in new' C:/Users/Dave/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/TIG-ShadowProjector/TIG-ShadowProjector_Loader.rb:18:in block in module:ShadowProjector'
                                            SketchUp:1:in call'
                                            • 4 / 7
