    File won't open after installing v-ray
    renderpluginsextensions
    7 Posts 3 Posters 1.1k Views 3 Watching
      pia_r
      Hi everyone, I have a problem with v-ray. I have sketchup 2015 and v-ray 2.00.25244.I'm doing an interior desing. I could work fine with my file before i install v-ray, but when i install it, the file won't open 😒 The file is 712MB.
      Please help me!!! 😒 😒 😒
      • soloS Offline
        712 MB?
        In my limited experience I'd say it's maybe a little too big for Sketchup.
        However, if you insist it will work then uninstall Vray and try again, please post images of the model with poly count as you may just be the winner of the biggest model loaded in SU.
          pia_r
          Oops it's too big? 😳
          I guess the file increase that much 'cause the components i'm using
          I post an image with model info
          what am I doing something wrong?
            pia_r
            Searching in the forum I found that SU use one core an V-Ray use all cores.
            So, it would be a good idea overclock CPU?
            PC Specs:
            CPU: Intel Core i7 5820K 3.30GHz
            Motherboard: ASUS x99-DELUXE
            RAM DDR4 16GB
            GPU: NVIDIA GeForce GTX 970 SLI
            If I overclock CPU, it would help rendering?
            • soloS Offline
              I suspect it may have a lot to do with the over 1000 materials.
              • panixiaP Online
                panixia
                +1
                i also suspect that at least 950 of them come from wharehouse components with no cleanup..
                  pia_r
                  Thanks a lot for the reply! I'll check that πŸ˜„
