[Plugin] FredoTools - v4.5c - 24 Jun 24
NEW RELEASE: FredoTools v2.7e - 29 Apr 15
FredoTools 2.7e is a release for FredoTools::SolidVolume v1.1d, which computes the volume and faces area of solids in the selection. This fourth version includes a fix for the correct display of the main dialog box.
Now it works perfect
thank you -
great plugin, complete and really functional
NEW RELEASE: FredoTools v2.8a - 09 Jul 15
FredoTools 2.8a is a minor release for:
- SolidVolume, which now accepts solids with holes
- ReportLabelArea, which now computes the correct area removing the space taken by the glued componentss in cut opening mode.
Warning:
Please upgrade to LibFredo6 6.8c if you installed FredoTools v2.8.
There is a bug in FredoTools::Convexify, which is fixed in LibFredo6 v6.8c.
Sorry for inconvenience
Fred
Thanks Fredo!
Hello Fredo, je viens de passer sur skp 2015. J etais sur 2008 et tout allait bien et voici ce qui m'arrive malgré pas mal de tentatives.. ça fait 15 jours que c'est comme ça... et moi SKP sans libfredo, c'est comme si on me coupait un bras...tu saurais ce que je pourrais faire pour telecharger ton plugin et qu il fonctionne ? je suis sous mac yosemite ( non de Dieu que Mavericks me manque!!!)
Merci de tes lumières.... si tu en as !
ElviremErreur de chargement du fichier Fredo6_!LibFredo6.rb
Error: #<ArgumentError: invalid byte sequence in UTF-8>
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:716:inmatch' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:716:in
block (2 levels) in load_from_config'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:715:ineach' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:715:in
block in load_from_config'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:713:inforeach' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:713:in
load_from_config'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:inblock in load_all_plugins' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:in
each'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:inload_all_plugins' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:786:in
load_from_config'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:instartup' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:338:in
module:LibFredo6'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in<top (required)>'
Where downloading Move along ???????
It's part of this collection and you can download it at the first post or with the Plugin store.
Make sure that you have installed LibFredo too.
VOLUME Calculator.
I am getting a very large difference in calculated volumes between what SU displays in the Entity Info and what the volume calculator comes up with. I suspect it is due to a small sized object with many very small facets.
Can I send you the model to look it over?
Model created in SU2015, 64-bit. Windows 7.
Yes. Please send the model.
By the way, do you already know which result is the correct one?
Please see your messages. Thanks.
Is it possible to increase the size of the dialog box? On my screen it is so small it is almost impossible to see the buttons! I wondered whether there was an option but because of the small size I was unable to see it? Thank you
NEW RELEASE: FredoTools v3.0a - 20 Oct 16
FredoTools 3.0a is a release mainly related to FredoTools::ThruPaint with the introduction of a Purge feature.
NEW RELEASE: FredoTools v3.0b - 31 Oct 16
FredoTools 3.0b fixes a major bug bug preventing FredoTools to load properly for SU versions < 2014. So, if you run SU6, SU7, SU8 or SU2013, please upgrade to v3.0b.
Hi Fredo,
Thanks for continuing to update your tools.
I'm having an issue with ThruPaint where I invoke the tool and it promptly does nothing. Nothing shows in the error console, it just refuses to come up.
EDIT:]Woops! Mybad. There is something in the Ruby console.
(eval):1: warning: already initialized constant T7
Hope this helps.
It was working fine for me prior to me updating things over the last two days. I'm using the latest downloads of FredoTools, and FredoLib, right out of the SU Plugin store.
I have double-checked the plugin footprint, and it looks like it should look.
Still on SU7.1.6860, Win7Prox64
Second update.
I have no idea why this worked but I unchecked Fredo Tools in the extensions, restarted and now Thrupaint is working just fine, as is everything else. The weird thing is, I did not re-enable The Fredo6 Fredo Tools extension, yet things are working fine.Update weirdness makes my head hurt,
I guess there's nothing to worry about after all.
Thanks in advance,
Cathryn -
Bonjour Fredo
Puisque c'est ma journée "réclamations", après LibFredo6, je reviens avec FredoTools.
Depuis un certain temps, je ne me souviens plus trop quand d'ailleurs (peut-être depuis ma migration vers Windows 10, il y a seulement quelques mois), la fenêtre qui s'affiche à l'écran après avoir lancé l'outil "Étiqueter les Surfaces" se trouve réduite en hauteur tel que montré sur la capture d'écran qui suit.
Ce n'est pas un gros problème, mais dans sa taille d'origine, je suis pas obligé de jouer de l'ascenseur.
This is due to SU2017, which is messing up dimensions in web dialogs.
Can you tell me if you can resize the dialog box?
Fred
Non, la boîte de dialogue n'est pas redimensionnable.
NEW RELEASE: FredoTools v3.0c - 13 Feb 17
FredoTools 3.0c fixes sizing issues for some dialog boxes in SU2017
