    Drawing with GL
    24 Posts 4 Posters 1.3k Views 4 Watching
    • CadFatherC Offline
      CadFather
      John, Thanks for this.
      i actually did try it wrapped up in a class method, and called it from the
      Sketchup.active_model.select_tool Gridz.new
      still had no result. at least i now know where not to look! πŸ‘
        CadFather
        that was good (if only from a neurological perspective), seems like what i missed was 'onMouseMove invalidate' (thanks to the Chris F example you linked). however the line disappears when orbiting - even if i use the invalidate on onMButtonDown. πŸ˜’
        require 'sketchup.rb'
        class Layz
        	def activate
        			@p1=200,200,0
        			@p2=600,600,0
        	def onMouseMove(flags, x, y, view)
        			view.invalidate
        	def draw(view)
        			model = Sketchup.active_model
        			view = model.active_view
        			view.line_width = 10
        			view.drawing_color = "red"
        			view.draw2d GL_LINES, [@p1, @p2]
        	end   #def
        end # class
        if !file_loaded?(File.basename(__FILE__))
        UI.menu("Plugins").add_item('Layz'){ Sketchup.active_model.select_tool Layz.new }
          driven
          @cadfather said:
          ...however the line disappears when orbiting -
          even fredo's toolbars disappear when you orbit...
          I think SU suspends the GL drawn elements to help cope with showing the model...
            CadFather
            ..makes sense, though when i look at those aspect ratio bars on the sides (like advanced camera tools), they do stay on screen.
              driven
              they are completely controlled by SU so I guess they has that option...
              but not us...
              EDIT: watermarks will also stay put, they may be using those...
                CadFather
                mmm maybe so, advanced camera tools is a ruby script though.
                unfortunately it's flipping scrambled πŸ˜’
                  When you orbit the Orbit tool is pushed into the tool stack - suspending your tool. So you have to invalidate the view in the resume event. You also want to invalidate the view on deactivate as otherwise your drawing might stick around after your tool is not active any more.
                    CadFather
                    not sure, even with the invalidate on resume, no joy. though i could be doing it wrong.
                    def resume(view)
                    view.invalidate
                      driven
                      what are you aiming to achieve?
                      there may be other ways...
                        CadFather
                        well, first of all i'm trying to avoid going to bed! πŸ˜†
                        i wanted to make a plugin that would show aspect ratio bars and even a grid system, it's almost there, but for the orbit bit(!)
                        this is the beast i'm working with:
                        class Gridz
                         def activate
                         		@width3 = Sketchup.active_model.active_view.vpwidth/3
                        		@height3 = Sketchup.active_model.active_view.vpheight/3
                        		@p1 = @width3, 0, 0
                        		@p6 = @width3, @height3*3, 0
                        		@p2 = @width3*2, 0, 0
                        		@p5 = @width3*2, @height3*3, 0
                        		@p8 = 0, @height3, 0
                        		@p3 = @width3*3, @height3, 0
                        		@p7 = 0, @height3*2, 0
                        		@p4 = @width3*3, @height3*2, 0
                        		view.invalidate
                         def resume(view)
                        		view.invalidate
                         def suspend(view)
                        		view.invalidate
                        def draw(view)
                        		view.line_width = 1
                        		view.draw2d GL_LINES, [@p1, @p6]
                        		view.draw2d GL_LINES, [@p2, @p5]
                        		view.draw2d GL_LINES, [@p8, @p3]
                        		view.draw2d GL_LINES, [@p7, @p4]
                        end   #def
                        def deactivate(view)
                        		view.invalidate
                        end # class
                        UI.menu("Plugins").add_item('Grid'){ Sketchup.active_model.select_tool Gridz.new }
                        file_loaded(File.basename(__FILE__))
                          driven
                          have you ever read 'Automatic Sketchup'?
                          btw: I win the insomniac award...
                          # Create a 4x4 cube
                          square = Sketchup.active_model.entities.add_face [-2,2,0],
                             [2,2,0], [2,-2,0], [-2,-2,0]
                          square.pushpull -4
                          #Chapter 11; The SketchUp User Interface Part 2; Views, Cameras, Tools, and Pages 251
                          # Access the Pages container and get the time
                          pages = Sketchup.active_model.pages
                          now = Time.now
                          # Create the first page
                          pg1 = pages.add "Pg1"
                          pg1.camera.aspect_ratio = 2
                          pg1.shadow_info["DisplayShadows"] = true
                          pg1.shadow_info["ShadowTime"] = now
                          # Create the second page
                          pg2 = pages.add "Pg2"
                          pg2.camera.aspect_ratio = 1.5
                          pg2.shadow_info["DisplayShadows"] = true
                          pg2.shadow_info["ShadowTime"] =
                             now + (60 * 60 * 6)
                          # Create the third page
                          pg3 = pages.add "Pg3"
                          pg3.camera.aspect_ratio = 1
                          pg3.shadow_info["DisplayShadows"] = true
                          pg3.shadow_info["ShadowTime"] =
                             now + (60 * 60 * 12)
                          # Select the first page
                          pages.selected_page = pg1
                            CadFather
                            John...looking at that code looks like you do need the rest! πŸ˜„
                            is that a taster of what's inside the book? i'll check it out. πŸ‘
                              driven
                              yes it's straight out of the book, did you run it?
                              it does change the aspect ratio bars when you play the animation...
                              and they don't disappear when orbiting...
                              • jiminy-billy-bobJ Offline
                                jiminy-billy-bob
                                It's not specific to the Advanced Camera Tools. You can set the camera's aspect ratio yourself, and you'll get the same gray bars on the sides.
                                  driven
                                  @jiminy-billy-bob said:
                                  ...You can set the camera's aspect ratio ourself, and you'll get the same gray bars on the sides.
                                  but, like a lot of examples in the API, it won't just 'work'...
                                  attach it to the view...
                                  Sketchup.active_model.active_view.camera.aspect_ratio = 1.414
                                  that will give you Landscape A4 paper size margins, 1/1.414 will be Portrait...
                                    CadFather
                                    that's the thing, often i try things out from the api docs and when it doesn't work, i'm not sure if it's me (my preferred choice) or the doc itself (...)!
                                    John, i hadn't even notice it was relevant... will look it up.
                                    JJB, the aspect ratio bars seem to be governed differently, when you try with lines it doesn't stay on screen (on orbit)
                                    going to 'try' and take a break this evening... my skull hurts! 😲
                                      CadFather
                                      ok, i came to the conclusion that this is impossible. the orbit tool does not allow for anything else to be active. (and the draw method can't be called outside of a 'tool'). πŸ‘Ώ
                                        driven
                                        why do you want the grid lines?
                                          CadFather
                                          ..was trying to fit a 'rule of thirds' on the screen, but trying to avoid using styles.
                                          this is what i'm aiming at:
                                          as plan B, i tried saving the current style as a variable, load my 'ratio style with the grid', and reload the previous style upon exit of the tool.
                                          Incidentally, i found no way to add a style that's already 'in model' - has to be from a saved file. (also no way to save a style to disk from ruby it seems). πŸ˜’
                                            driven
                                            that's doable as a watermark...
                                            but, you need to generate the watermark to match the users viewport width/height...
                                            that's not as hard as it seems, you can use a webdialog with those as 'client' width/height...
                                            in the webDialog you add a html5 canvas to draw the grid...
                                            the blank canvas is centred on the page...
                                            its height is vph and it's width is 'paper' width [ vph x paper ratio ]...
                                            grid width is (canvas width minus line weights) Γ· 3
                                            height is (vph minus line weights) Γ· 3
                                            line weights e.g 0.5 x 5
                                            your body background color will show as page margins and the canvas bg needs to be white...
                                            once drawn, write the image to file then load it as a watermark...
                                            you need to make the white bg transparent, I'm not sure how on 'windose' from code...
                                            I think you can toggle watermarks from ruby, but it may need 2 scenes...
                                            I could dig out some similar code, but you might think it's unrelated...
