    How to model an existing Kitchen?
    4 Posts 3 Posters 465 Views 3 Watching
    • T
      tallbridgeguy
      Hi, my wife and I want to update our old kitchen. I have never drawn up an existing kitchen before and I was wondering if I could get some tips?
      I thought I would,
      1. Measure what I could (width, height, cabinets)
      2. take pictures on my iphone and add them as textures to the model
      3. take images with me to big box stores for reference/ideas
      So I'm wondering how kitchen remodelers actually use sketchup in this way? We are looking to replace existing counters, flooring and add some lighting.
      Thanks in advance!
      Stuart
      Nielsen
      http://www.tallbridgeguy.com/
      • pbacotP
        Depending on what you are planning to do in the kitchen... I wouldn't model what you are going to get rid of (e.g. existing cabinets) except as an exercise to familiarize yourself. I guess if you don't know the standard sizes of things this wouldn't hurt. Also why texture your existing model in this way? I assume you'll be redoing all or most finishes. Photos and physical samples will suffice in design decisions. Then if you are able, texture the proposed work. For lighting you can use photoshop to depict or you'll need to use a rendering package.
        There's all sorts of cabinet plugins if you are redoing the cabinets. Personally, because kitchens are only a part of my work. I model the basic counter tops and a box for the cabinet then apply doors and drawer fronts--since I am not actually making cabinets myself. In that vein, remember as you work that the cabinet maker and contractor will come and make detailed measurements themselves, and will also introduce features you never thought of. Your initial work is to show/dimension the space, define your needs, and illustrate the intent in features and appearance. You can model an exact cabinet design (door styles etc.) or leave it "generic" (simple panel or slab doors) before you actually choose cabinets at the showroom.
          slbaumgartner
          I agree with @pbacot. The only reason to care about the existing is if you plan just to update everything with identical sized new. And even then a textured model of the existing stuff won't give you any feel for how new stuff will look in the space. Seems like wasted effort.
          I start with measurements of the space, including doors, windows, and anything else that can't or won't be redone (e.g. plumbing or electrical). I build a model of these features. Then I place nominal models of cabinets, appliances, sink, etc. to play around with how the space "works". SketchUp's slicing, walkaround, and basic orbit facilities are very helpful for imagining cooking a meal in the kitchen. The trick of painting a transparent material on the outside of walls so you can look through them from outside is also very helpful.
          Sometimes your predecessor did a good job thinking it through, but many times a different arrangement will work better. Sometimes the typical sizes of items have changed over time. This is particularly true when planning for refrigerators and ranges, whose sizes vary widely, and where quasi-industrial units have become popular.
          • T
            tallbridgeguy
            Both great replies, thanks very much for the advice! Now I just have to get started building...
            s
            Nielsen
