    Finally gone back(i mean forward) to a PC!
    127 Posts 29 Posters 19.6k Views 29 Watching
    • michaliszissiouM Offline
      michaliszissiou
      They said trees in my area must have increased the humidity causing screen to steam up?!!
      πŸ˜†
      For my apple display, they said, I was smoking. They replaced the screen panel three times. They replaced power supply the fourth time and now it perfectly works. The power supply was the problem, costed them 4 displays. Nice
      The other story with my macpro and the heat sink of the northbridge was funnier though.
      When they realized I was right and fixed it, they had to say something…
      "we found some hair" they said. Do you have a pet?
      "No" I replayed, "these are mine, I'm a huge and hairy guy, and I'm coming to take it back right now"
      I'm not huge or hairy but the trick worked.
        roland joseph
        Build-a-PC: if you went this route chances are you're doing it yourself, and can easily find the culprit, get a faulty part swopped out / replaced rather quickly, and off you go - no waiting on shipping times and wait in line until technician can look at it.
        For those that can, hands down, building is the answer. I regret not learning how to repair my car from the beginning considering I was going to drive one all my life.
        • olisheaO Offline
          olishea
          πŸ˜† πŸ˜† πŸ˜†
          They tried that one with me too!! Seriously!
          I took my brother's iPhone to the "Genius" Bar as it kept losing signal....
          30 seconds in, after an otoscope inspection, the "genius" condescendingly pulled out a single dog hair with some tweezers.
          They tried to say the hair is causing the problem. A dog hair! Anyway, 2 hours of arguing later they gave me a new phone. πŸ˜† πŸ˜† πŸ˜†
          oli
            michaliszissiou
            Please Oli,
            My message was, be like a hairy huge guy. It works. Give them something to thing about.
            • neetsN Offline
              neets
              Where's the render test??!! I scrolled through all of that 'man waffle' for NOTHING???!!! πŸ˜‰
              Interested to know more about me and my 3D Visualisation work? Then you want to click right here: http://anitabrowndesignstudio.com/
              • olisheaO Offline
                olishea
                haha yeah i should do comparisons to my old rig it would be quite amusing!
                oli
                • neetsN Offline
                  neets
                  So you haven't tested the render times yet?! I'd be taking a day off work to do that!! So jealous that you have an i7! I'd love a dedicated rendering workstation. I'm still using my DELL laptop!!
                    driven
                    @olishea said:
                    Which one will be quicker?
                    good point made by neets...
                    • olisheaO Offline
                      olishea
                      Has anyone seen a thea test scene anywhere? For render times. There is a twilight one knocking about that I could test with too. Can compare then with other PC specs.
                      Oh I know it's rapid, I just don't know how much more rapid than my old setup!
                      oli
                      • BoxB Offline
                        Oli, get on with your work and enjoy your new setup.
                        The rest of the gibberish and testing is irrelevant unless .............
                        so many different and unrelated settings and hardware configurations.
                          cadmunkey
                          Oli try this one here for Thea, 32 spp and 2048 spp and post results. Quite a few different cards tested in that thread.
                          https://thearender.com/forum/viewtopic.php?f=93%26amp;t=16544
                          • olisheaO Offline
                            olishea
                            Thanks cadmunkey. That's exactly what I'm looking for.
                            I know Box, I'm not really one for comparing but would be interesting to see anyway. If even just to see how much quicker than my old Intel Core 2 Duo!
                            oli
                            • stefanqS Offline
                              stefanq
                              Don't forget about temps Oli. You got one hot cpu - not sexy hot- and I know that, running some benchmarks (I think the last version of Prime) will make the cpu to throttle. I didn't find to much info about the temps when rendering, so, that's why I'm so curious.
                              Anyway, if you are below 70 degrees Celsius, you should be fine.
                              Cheers!
                              Ps: I almost had the money to build a similar rig, based on the same cpu, but something came up, and now I'm breaking my bones again, for extra income. Tough times.
                              • jeff hammondJ Offline
                                @olishea said:
                                So yeah, not all Apple repairs go as smoothly as you claim!
                                i didn't claim they go smoothly.. i said there are other ways to have a mac fixed besides it being shipped away and wiped clean (in response to juju)
                                and saying this again:
                                it's about nearly anything to be said in a mac vs pc argument, there are also valid counterpoints.. from either side.
                                i'm not arguing 'mac is better'.. i think if you re-read some of what i wrote, you'll see thats not my stance..**
                                build your own.. right. cheaper, more customizable, more fun if that's what you're into, easier user serviceability (i mean, you built the thing.. swapping out a part should be cake), etcetc.. that's fine and i really don't think people are arguing against that.. but at the same time, you (in general) have to recognize the majority of people don't build their own computers.. it's not as if people don't understand what you're saying and that we need it explained.. just that most people would rather buy a plugnplay electronic.
                                on the mac side of that, there are people building their own and using osx.. either hackintosh or buy a 4.1 box then pimp it..
                                probably easier for this stuff to happen with a windows based mindset but it's not the only way nor is it the best way.. to a certain degree, whatever is best for that individual is what's best.
                                ** on the bit about repairs though, i would actually argue mac is better.. but it's not really an argument.. this is year after year from consumer reports and the like:
                                In our latest reader survey of computer technical support, Apple bested its own scores from last year's survey and walloped other brand-name computer manufacturers.
                                The company scored far higher than the other big companies for the elements that make for successful online and phone support: ease of contacting staff, clarity of advice, technical knowledge, patience, and time for follow-up.
                                Apple's in-house technical support service, the Genius Bar, rated as high as support provided by phone or online. Whatever way readers asked for tech helpβ€”by phone (the most common way), online, or in personβ€”Apple was also able to solve more computer problems. Independent shops that make custom computers came closest to Apple.
                                Clearly, there's room for improvement in tech support: 24 to 40 percent of respondents who sought phone or online help from makers of Windows-based computers said the staff's patience, knowledge, or clarity was fair at best.
                                (though in my experience at least, macs don't break to begin with.. probably most other computers don't break either)
                                  roland joseph
                                  That sums it up. πŸ˜† Break downs are rare. The pc I just retired went 12 years with out a hick-up. It is still in use.
                                  • neetsN Offline
                                    neets
                                    Why are we resurrecting this Mac v PC argument again?! Guys, let it go! There are valid reasons to choose either (although I'm Windows All. Day. Long). When I was making a decision 4 yrs ago as to which one I would choose, I did a bit of research and found out that Mac computers were problematic when it came to design/CAD software. It was a no-brainer for me to opt for a PC. I just didn't want that risk. Could be different these days though. I'm not sure if there are still issues in that area for Mac.
                                    Oli, don't feel under pressure to try and illustrate ridiculous rendering times in comparison to your previous machine. I'm not interested in a comparison of that nature. I'm just interested in your render times full stop! Can you do a test using Maxwell Render, to give me a better idea? πŸŽ‰
                                    Anita
                                      isn't that what you just did? πŸ˜•
                                      • neetsN Offline
                                        neets
                                        Yea, alright. Fair point. Well then, feel free to respond πŸ˜‰
                                        • pbacotP Offline
                                          The "problematic" issue for Mac involving CAD was probably Autodesk decided not to support Mac OS in the past. I've used PC and AutoCAD some in training, but I have used Mac since 88 for CAD. There's no problem. AutoCAD is now back on Mac to some extent, but I never wanted to use it for my work in the first place.
                                          • neetsN Offline
                                            neets
                                            @numerobis said:
                                            http://www.maxwellrender.com/benchwell πŸ˜‰
                                            a 4970K should be around 10 min and ~BM450
                                            But you have to read the list very carfully today and compare the results and infos, because it is messed up with many bad entries without specs and info. Results of clearly overclocked machines without any info about the real clock rates - the GHz number in the Processor column only shows the stock speed.
                                            Thanks for this; I remember checking the Benchwell list previously but, like you've said, I was concerned about the authenticity of the specs! Oli's result might be more accurate.
                                            • 6 / 7
