    Entity Info Units
    5 Posts 2 Posters 859 Views 2 Watching
    • C
      Calstock
      Is there a way to retain my drawing units as millimeters and yet have the area shown in "Entity Info" in square metres ? I find this function very useful and yet mentally decoding all those digits is sometimes awkward !
      If this is not possible, perhaps there's a plugin that displays area / volume in the desired units ?
        It's not possible to change what's in Entity Info via the API.
        Having options for length/area/volume have long been requested - e.g. mm/m2/m3
        But it's not [yet] available in Model Info > Units
        There are several tools around, e.g. my 'Area Text Tag' tool.
        http://sketchucation.com/pluginstore?pln=TIG_AreaTextTag
        • C
          Calstock
          Thanks Tig.
          I suppose the obvious answer is to change my default units to Meters and then the volume would be in square metres. I'll give this a try. I did try it a year or two ago for different reasons, (can't remember what), and I struggled. The main reason being, (as I'm sure many will have found), is that you get so used to entering dimensions in your "usual" format, that you keep tripping up initially.
          I know it's just a matter of sticking with it and then all my volumes & areas will be in m2 / m3 as I would wish.
            Model Units set to ' meters' gives both the Entity Info reported areas and volumes in 'meters'.
            Then to avoid having to enter 0.123 for a mm value. try to get into the habit of using a units suffix.
            So working in meters you type a length of 123**mm** + <enter> it's then 0.123m long πŸ˜„
            • C
              Calstock
              That's a good idea.
