    [Plugin] VisMap 2 - Improved Layer/Scene Visibility Map
    41 Posts 21 Posters 29.8k Views 21 Watching
    • H Offline
      haynesc
      ok im now getting this message:
      Error Loading File vismap2_menu.rb
      can't convert nil into String
      • josephkim626J Offline
        josephkim626
        Hi, I have been using this plugin until 2014 came out. It hasn't been working for sometime. Will there be any future development?
          Jim
          Martin gave me the ok to update this for Sketchup 14/15. I might not have time until the weekend.
            driven
            can you leave out the dated css??
              db11
              That's great news Jim. Will look forward to the update.
                josephkim626
                Same here!
                  Jim
                  Here is version 2.1.
                  • Updated to work with Ruby 2 versions of SketchUp (version 14 or later.) Use the original version if you want to use Vismap2 on earlier versions of SketchUp.
                  • Made a SketchUp Extension to allow enabling/disabling in extension managers.
                  I am not sure how to handle distribution. I am unable to put it in the Plugins Store under Martin's name. That would make it harder to do further updates. I could post it under my plugins, but not sure if it would cause much confusion.
                  vismap-v2.1.rbz
                    Jim
                    At some point. Can you help? Do you do Bitbucket/git?
                      driven
                      git, a bit...
                      I clone things to my mac, mess about, then panic when it asks if I want to commit changes...
                      I may still even have css for this one, a 'native' os look...
                        glro
                        works perfectly again in SU15
                        thank you
                        • Bob JamesB Offline
                          Bob James
                          Thank you for updating it! Once again, a very useful tool.
                            josephkim626
                            I also conform that it works fine in 2014 as well.
                            Thank you so much.
                              Jim
                                Bob James
                                The download from your website does not contain the file vismap2_extension.rb
                                I have it and it identifies the Version as 2.1
                                VisMap appears in the list of extensions in SU and operates as expected with or without the file vismap2_extension.rb. I assume from this that the file is no longer needed. Correct?
                                Magically, if I add a # in front of vismap2_menu.rb to make it #vismap2_menu.rb, SU complains on startup, but VisMap appears at the top of the extension list!!
                                VisMap is on neither Extension Warehouse or SketchUcation Plugin Store. IMHO it should: it's a great tool for people with large numbers of scenes (like me).
                                It also does not have a toolbar icon. IMHO I think it needs one.
                                  Bob James
                                  I vote for you to put it in the store(s) as a Tig-VisMap2.1
                                    laaljohn
                                    This plugin looks great and ideal for what I need. Unfortunately I can't get it to work and keep getting the following error message.
                                    I'm running SU8, and have purged the components, saved the model and tried running VisMap2 again, and get the same error. This occurs on both model I'm working on with ~25 layers and scenes, and a newly created model with 3 layers and 4 scenes.
                                    Any suggestions gratefully received.
                                      monkers
                                      Just bumping this thread guys. Would love to see this working in later versions of SU 18-19-20 etc
                                      In SU19 I get this message. I'm not sure why because in a blank scene it can get data fine. But when I try load it in a more complex scene I get the below message. I have tried removing symbols and special characters such as _ & etc from both scene names and layers names with no effect.
                                      Error Analyzing Model
                                      Reported Error - undefined method `each' for nil:NilClass
                                      Try Window/Model Info/Statistics Purge Unused
                                      and then try Vismap again.
                                      I would be happy to buy the plugin or pay for time to get it working if someone is able to have a go at it. Would be pretty useful for me.
                                      Cheers
                                        jsteacy
                                        Cheers
                                        I asked martin (the original developer) years ago if he would let me find someone to fix it. He said yes, and I got distracted. But about a year ago I found someone to fix it. I just emailed Martin for permission to post the corrected files. It is an amazingly useful tool and I haven't had any trouble with the fixed version so far. If I can share it I want it to be 'by the book' in the legal sense which I have no experience in and not sure what it means/how to go about it. I figured verifying with him that it is ok post is step one.
                                          jsteacy
                                          Hi, I received permission to post the fixed Vismap. To the Sketchucation world, how do we get it into the Plugin store?
                                            monkers
                                            Thats fantantasic I really appreciate both you and Martin getting back to us here. I received your email but no attachment. Its appears email filters do not like the rbz files. There is an option to attach the file on this forum just below the comment text box there's an upload attachment tab. Maybe give that a whirl at least that way its here for everyone.
                                            • 3 / 3
