    Im looking for Simple Bridge / Loft Tool
    5 Posts 4 Posters 803 Views 4 Watching
    • H Offline
      HirokaMatsuiko2015
      hi
      im looking for simple bridge or loft tool ( connect 2 shapes with same amount of vertices to bridge )
      i tried fredo tools loft but im getting constant crashes everytime i made mistake of selection because of clumsiness and right now im looking for alternative or more simplier for bridging with no command bar
      thank you
      • sdmitchS Offline
        sdmitch
        Could you post a screen shot of the shapes you are trying to join and illustrate how you would like them joined?
        http://sdmitch.blogspot.com/
          Curious because Curviloft is some easy! 😲
          Here CurviLoft/ Loft along Path
          Just Copy Past your profils for be sure to have the same number of segments! πŸ€“
          And put first profil perpendicular to the path!
          • H Offline
            HirokaMatsuiko2015
            http://zippy.gfycat.com/BelovedMeekBlacklab.gif
            im using curviloft right now for bridging
            but im looking for quick bridge ( no command bar / prompt ) similar to this GIF image
            it will bridge instant with if only have same amount of vertices / edge
            • jeff hammondJ Offline
              hmm.. idk.. i thnk curviloft is your best bet for this.. you can window select all those at once and loft it..
              set it to straight (junction by connected lines) with segments set to 1 for the results your showing in the gif.
