    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 402.8k Views 80 Watching
      dtrarch
      Hi Anton
      Any chance to look at the Menu/remember location question.??? 💭
      In any case.
      Happy New Year in the Wetlands of Ore.
      Dave
        Anton_S
        Sorry, I forgot.
        There, try this one! There was literally a bug in script that moved the dialog to the upper right corner of the viewport. I think it is fixed now. I would like you to verify it before I post it to the PluginStore though.
        Here it is:
        [attachment=0:3bp9dg2h]<!-- ia0 -->ams_WindowSettings_4.2.0.zip<!-- ia0 -->[/attachment:3bp9dg2h]
          dtrarch
          Anton
          I checked multiple times and good news as it sticks as SU Title on selected screen or window location.
          The select mode to access your menu is a little odd as when the SU title is selected one must then move the cursor off the title box and then the Window Settings title shows but is greyed out until the pull down arrow is selected.
          Double click on SU title has no effect to get the WS menu.
          Hmmmmm??
          Dave
            Anton_S
            Okay, thanks for the good news.
            Are you asking why WindowSettings drop-down menu doesn't activate when you select the WindowSettings title bar, move the cursor, and then deselect it?
            That's because the title bar is designed for two purposes. One to move it and the other to activate the drop-down. It will be odd if the person moves the dialog and figures that the drop-down has activated too.
            So, here is how it works:
            If user selects the title bar without moving the cursor the drop-down mode is activated.
            If user selects the title bar and moves the cursor (while the mouse button is down) the move mode is activated.
            Is that what you were indicating odd?
              dtrarch
              OK Anton
              Yes it works as you have intended and described. 👍 👍
              I guess when I saw the SU title box I expected to double click on it to get/select your Green title bar/options.
              I did not expect to have to move off the SU title bar to get to your app.
              That's all. ☀
              Thanks for all the trouble too.
              Dave
                Anton_S
                Thanks for confirming.
                I posted the new release and added usage instructions.
                • shake1S Offline
                  shake1
                  Hi, first of all, - thanks for the plug!
                  Question: when I click "hide floatin dialogs" v-ray windows are still visible.
                  Is it possible to do these windows have been hiding?
                  Win 7/64
                  SU 2015/64
                  V-ray 2/64
                  http://i.imgur.com/5i0Bzsa.jpg
                    Anton_S
                    Hello Vladislav,
                    Thanks for feedback. By viewing your screenshot, it seems to me that all Vray windows in the background are not part of SketchUp WebDialogs. I think your Vray windows are launched from a separate application. The show/hide dialogs option was only intended to hide all WebDialogs in SketchUp. A WebDialog is a window/dialog that was created through SketchUp API and not other source. I might add a feature to show/hide "special" windows, like these ones, but this will require me installing Vray and looking in the classification of these windows. Anyway, I will see what I can do.
                    Anton
                    • shake1S Offline
                      shake1
                      Hi, Anton, thanks for the reply, it would be good to implement this feature.
                      You can download vray from here:
                      (V-Ray for SketchUp demo builds 32/64)
                      http://www.chaosgroup.com/en/2/downloads.html?s=v-ray-sketchup
                        Anton_S
                        Done! Get the AMS Library 2.2.0
                        • shake1S Offline
                          shake1
                          It's fantastic, thank you !!!
                            GonzoRus
                            Very Mega Super Cooooool!!!!
                            • DimaV83D Offline
                              DimaV83
                              Anton, am I right, that Full Screen will maximise SU only to the primary screen? Is it possible for plug-in to make it Full Screen on the current screen? (or add an option what screen to use for Full Screen if there is more than one connected)
                              P.S. Большое спасибо!
                                Anton_S
                                You're right, Dima. The full screen function associates to the primary screen. I will see what I can do to make it associate to the the desired screen. Thanks for your request.
                                  Anton_S
                                  Dima, I updated AMS Library. The full screen function should now, by default, set SketchUp full screen on the monitor SU window is associated to or the most present to. Update AMS Library to version 3.1.4 and the feature should work.
                                  I also added the feature to set SU full screen on all monitors combined, though I haven't implemented it into this plugin yet. For now, to set main window full screen on all monitors, paste this command into the Ruby Console:
                                  AMS::Sketchup.switch_full_screen(true, 2, 2)
                                  See documentation of this function for more details.
                                  • DimaV83D Offline
                                    DimaV83
                                    Thanks! It works fine, checked on each of 3 screens (across 2 video cards).
                                    (I have screens with different resolution and orientation, so full-screen across all of them will not be usable in my case)
                                      perroloco2000
                                      Hello
                                      Everytime I try to hide menu bar with AMS Windows Settings crash my SU 2016
                                      I´m using AMS Window Setting 4.2.0 and AMS Library 3.1.4 (in Win10)
                                      Please help, is really useful optimize my screen when I work on the laptop
                                      Thanks for your greats plugins
                                      • romboutR Offline
                                        rombout
                                        Is there a option to use this on mac? Is the code that much different when using plugins on apple machines?
                                          Pherim
                                          Hello,
                                          just a small thing, but I noticed that when I set Floating Toolbars to hidden, save the settings and enable "Retain on Start", only some of them are hidden after restarting Sketchup.
                                            Anton_S
                                            @Rombout Currently this plugin is only workable on Windows. Mac OS X API is too different from Windows API. And I don't mean SketchUp Ruby API.
                                            @Pherim Thanks for your report. I will get it fixed soon.
                                            • 14
                                            • 15
                                            • 7 / 15
