    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 451.4k Views 80 Watching
      dtrarch
      Anton
      Here are my setups for your plugin.
      SU 2014 Pro (works properly)
      Lib 1.0.8
      Win 3.8.0
      SU 2015 Pro 64
      Lib 2.0.0
      Win 4.1.0
      Perhaps the problem is in not having the SU title stay with your menu(s)then attached.
      In SU 2014 I select the SU title to drag and your menus stick to it and go along with it when dragged.
      Also my SU 2015 is 64 bit version.
      Hope that helps
      Dave
        Anton_S
        Version 4.1.5 Had been released!
        • Fixed pick and drag bug.
        • Adjusted close button size.
        • Disabled high contrast optimization.
        • Made compatible with IE9.
        Thanks do dtrarch for reporting the bug.
          dtrarch
          Noel Anton
          FYI
          Last update works properly but when moved to second screen and saved as template/file your title/pull down menu location is not remembered.
          It shows up on primary screen as SU title and then changes to your title when moved.
          I know you do not like the way the SU tiles look but I think this SU title must stick/remain when moved so that the saved file can remember the location as a SU function.
          Thanks again so much for all your good work and this super Plugin. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
          Cheers
          Dave
            Anton_S
            MMMOkay, I will look into this. ๐Ÿ˜‰
              dtrarch
              Hi Anton
              Any chance to look at the Menu/remember location question.??? ๐Ÿ’ญ
              In any case.
              Happy New Year in the Wetlands of Ore.
              Dave
                Anton_S
                Sorry, I forgot.
                There, try this one! There was literally a bug in script that moved the dialog to the upper right corner of the viewport. I think it is fixed now. I would like you to verify it before I post it to the PluginStore though.
                Here it is:
                [attachment=0:3bp9dg2h]<!-- ia0 -->ams_WindowSettings_4.2.0.zip<!-- ia0 -->[/attachment:3bp9dg2h]
                  dtrarch
                  Anton
                  I checked multiple times and good news as it sticks as SU Title on selected screen or window location.
                  The select mode to access your menu is a little odd as when the SU title is selected one must then move the cursor off the title box and then the Window Settings title shows but is greyed out until the pull down arrow is selected.
                  Double click on SU title has no effect to get the WS menu.
                  Hmmmmm??
                  Dave
                    Anton_S
                    Okay, thanks for the good news.
                    Are you asking why WindowSettings drop-down menu doesn't activate when you select the WindowSettings title bar, move the cursor, and then deselect it?
                    That's because the title bar is designed for two purposes. One to move it and the other to activate the drop-down. It will be odd if the person moves the dialog and figures that the drop-down has activated too.
                    So, here is how it works:
                    If user selects the title bar without moving the cursor the drop-down mode is activated.
                    If user selects the title bar and moves the cursor (while the mouse button is down) the move mode is activated.
                    Is that what you were indicating odd?
                      dtrarch
                      OK Anton
                      Yes it works as you have intended and described. ๐Ÿ‘ ๐Ÿ‘
                      I guess when I saw the SU title box I expected to double click on it to get/select your Green title bar/options.
                      I did not expect to have to move off the SU title bar to get to your app.
                      That's all. โ˜€
                      Thanks for all the trouble too.
                      Dave
                        Anton_S
                        Thanks for confirming.
                        I posted the new release and added usage instructions.
                        • shake1S Offline
                          shake1
                          Hi, first of all, - thanks for the plug!
                          Question: when I click "hide floatin dialogs" v-ray windows are still visible.
                          Is it possible to do these windows have been hiding?
                          Win 7/64
                          SU 2015/64
                          V-ray 2/64
                          http://i.imgur.com/5i0Bzsa.jpg
                            Anton_S
                            Hello Vladislav,
                            Thanks for feedback. By viewing your screenshot, it seems to me that all Vray windows in the background are not part of SketchUp WebDialogs. I think your Vray windows are launched from a separate application. The show/hide dialogs option was only intended to hide all WebDialogs in SketchUp. A WebDialog is a window/dialog that was created through SketchUp API and not other source. I might add a feature to show/hide "special" windows, like these ones, but this will require me installing Vray and looking in the classification of these windows. Anyway, I will see what I can do.
                            Anton
                            • shake1S Offline
                              shake1
                              Hi, Anton, thanks for the reply, it would be good to implement this feature.
                              You can download vray from here:
                              (V-Ray for SketchUp demo builds 32/64)
                              http://www.chaosgroup.com/en/2/downloads.html?s=v-ray-sketchup
                                Anton_S
                                Done! Get the AMS Library 2.2.0
                                • shake1S Offline
                                  shake1
                                  It's fantastic, thank you !!!
                                    GonzoRus
                                    Very Mega Super Cooooool!!!!
                                    • DimaV83D Offline
                                      DimaV83
                                      Anton, am I right, that Full Screen will maximise SU only to the primary screen? Is it possible for plug-in to make it Full Screen on the current screen? (or add an option what screen to use for Full Screen if there is more than one connected)
                                      P.S. ะ‘ะพะปัŒัˆะพะต ัะฟะฐัะธะฑะพ!
                                        Anton_S
                                        You're right, Dima. The full screen function associates to the primary screen. I will see what I can do to make it associate to the the desired screen. Thanks for your request.
                                          Anton_S
                                          Dima, I updated AMS Library. The full screen function should now, by default, set SketchUp full screen on the monitor SU window is associated to or the most present to. Update AMS Library to version 3.1.4 and the feature should work.
                                          I also added the feature to set SU full screen on all monitors combined, though I haven't implemented it into this plugin yet. For now, to set main window full screen on all monitors, paste this command into the Ruby Console:
                                          AMS::Sketchup.switch_full_screen(true, 2, 2)
                                          See documentation of this function for more details.
                                          • DimaV83D Offline
                                            DimaV83
                                            Thanks! It works fine, checked on each of 3 screens (across 2 video cards).
                                            (I have screens with different resolution and orientation, so full-screen across all of them will not be usable in my case)
                                            • 11
                                            • 14
                                            • 15
                                            • 9 / 15
