    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 463.1k Views 80 Watching
    • shake1S
      shake1
      It's fantastic, thank you !!!
      • G
        GonzoRus
        Very Mega Super Cooooool!!!!
        • DimaV83D
          DimaV83
          Anton, am I right, that Full Screen will maximise SU only to the primary screen? Is it possible for plug-in to make it Full Screen on the current screen? (or add an option what screen to use for Full Screen if there is more than one connected)
          P.S. Большое спасибо!
            Anton_S
            You're right, Dima. The full screen function associates to the primary screen. I will see what I can do to make it associate to the the desired screen. Thanks for your request.
              Anton_S
              Dima, I updated AMS Library. The full screen function should now, by default, set SketchUp full screen on the monitor SU window is associated to or the most present to. Update AMS Library to version 3.1.4 and the feature should work.
              I also added the feature to set SU full screen on all monitors combined, though I haven't implemented it into this plugin yet. For now, to set main window full screen on all monitors, paste this command into the Ruby Console:
              AMS::Sketchup.switch_full_screen(true, 2, 2)
              See documentation of this function for more details.
              • DimaV83D
                DimaV83
                Thanks! It works fine, checked on each of 3 screens (across 2 video cards).
                (I have screens with different resolution and orientation, so full-screen across all of them will not be usable in my case)
                • P
                  perroloco2000
                  Hello
                  Everytime I try to hide menu bar with AMS Windows Settings crash my SU 2016
                  I´m using AMS Window Setting 4.2.0 and AMS Library 3.1.4 (in Win10)
                  Please help, is really useful optimize my screen when I work on the laptop
                  Thanks for your greats plugins
                  • romboutR
                    rombout
                    Is there a option to use this on mac? Is the code that much different when using plugins on apple machines?
                    • P
                      Pherim
                      Hello,
                      just a small thing, but I noticed that when I set Floating Toolbars to hidden, save the settings and enable "Retain on Start", only some of them are hidden after restarting Sketchup.
                        Anton_S
                        @Rombout Currently this plugin is only workable on Windows. Mac OS X API is too different from Windows API. And I don't mean SketchUp Ruby API.
                        @Pherim Thanks for your report. I will get it fixed soon.
                        • romboutR
                          rombout
                          Okay thanks for answering, I've found a working solution now which hides all panels
                          • L
                            lionk
                            hi @Anton_S,
                            the plugin dialog covered the trays in sketchup 2016. How to use the plugin correctly?
                              Anton_S
                              Left-click on the title bar of the settings dialog, hold the mouse button down, and drag it to any desired position on screen, where it doesn't intersect the other dialogs. You can also click on the x button to close it.
                                sarkarshomit
                                The plugin is crashing with this warning:
                                Error Loading File C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb
                                Error: #<NameError: uninitialized constant AMS::Timer>
                                C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb:69:in init' C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb:572:in <top (required)>'
                                C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load'
                                C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:80:in register_extension' C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:80:in module:WindowSettings'
                                C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:62:in `<top (required)>'
                                I had this working before on my SU16, but now after i updated it is crashing unfortunately 😞
                                PS: I am on Win7Ult 64bit
                                Explorer V9
                                PS PS: I had a backup of the older working version which i copy pasted and now it works, but am scared to update!!!
                                  Anton_S
                                  Sarkarshomit, have you upgraded to AMS Library 3.3.0, besides just upgrading the Windows Settings plugin? Because if you haven't, then the AMS Timer error could be depicted due to an old version of AMS Library.
                                    sarkarshomit
                                    Yes Anton, updated today the libraries...still this error...
                                    C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb:62:in init' C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb:562:in <top (required)>'
                                    C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:48:in register_extension' C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:48:in module:WindowSettings'
                                    C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:34:in `<top (required)>'
                                      Anton_S
                                      Just tested it on my Windows XP and Windows 10 64bit and it works fine. I really don't know what's wrong with yours. Perhaps you didn't overwrite all the files of AMS library. Try deleting an old version of ams_Lib and ams_Lib.rb from the "C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/" folder. Then install the latest version of AMS Library.
                                        sarkarshomit
                                        Thanks for the trick, it worked fine...regards....
                                        • B
                                          bharralure
                                          Bonjour Anton,
                                          J'ai installé "ams_WindowsSettings", et il me semble que je rencontre un problème d'affichage de "la boîte de dialogue des paramètre" (voir capture d'écran ci-après).
                                          Je suis sous "Windows 10 Famille v1607 64 bits", carte graphique "AMD Radeon R7 200 Series v16.6".
                                          J'ai installé (puis désinstallé et réinstallé à nouveau "ams_Lib.rbz_v3.4.1" et "ams_WindowsSettings_v4.2.1".
                                          Je joins également une capture d'écran des différents paramètres qui me sont accessibles depuis le menu "Fenêtre > Réglages"
                                          Auriez-vous une réponse à ce problème?
                                          D'avance merci.
                                            Anton_S
                                            Hello, bharralure,
                                            My apologies for not responding any sooner. It has been a while since I downloaded a localized SketchUp version. I fixed the bug with localized dialog. Please upgrade to version 4.2.2. Thanks for reporting.
                                            Regards,
                                            Anton
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
