    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 429.9k Views 80 Watching
    • shake1S Offline
      shake1
      Hi, first of all, - thanks for the plug!
      Question: when I click "hide floatin dialogs" v-ray windows are still visible.
      Is it possible to do these windows have been hiding?
      Win 7/64
      SU 2015/64
      V-ray 2/64
      http://i.imgur.com/5i0Bzsa.jpg
        Anton_S
        Hello Vladislav,
        Thanks for feedback. By viewing your screenshot, it seems to me that all Vray windows in the background are not part of SketchUp WebDialogs. I think your Vray windows are launched from a separate application. The show/hide dialogs option was only intended to hide all WebDialogs in SketchUp. A WebDialog is a window/dialog that was created through SketchUp API and not other source. I might add a feature to show/hide "special" windows, like these ones, but this will require me installing Vray and looking in the classification of these windows. Anyway, I will see what I can do.
        Anton
        • shake1S Offline
          shake1
          Hi, Anton, thanks for the reply, it would be good to implement this feature.
          You can download vray from here:
          (V-Ray for SketchUp demo builds 32/64)
          http://www.chaosgroup.com/en/2/downloads.html?s=v-ray-sketchup
            Anton_S
            Done! Get the AMS Library 2.2.0
            • shake1S Offline
              shake1
              It's fantastic, thank you !!!
                GonzoRus
                Very Mega Super Cooooool!!!!
                • DimaV83D Offline
                  DimaV83
                  Anton, am I right, that Full Screen will maximise SU only to the primary screen? Is it possible for plug-in to make it Full Screen on the current screen? (or add an option what screen to use for Full Screen if there is more than one connected)
                  P.S. Большое спасибо!
                    Anton_S
                    You're right, Dima. The full screen function associates to the primary screen. I will see what I can do to make it associate to the the desired screen. Thanks for your request.
                      Anton_S
                      Dima, I updated AMS Library. The full screen function should now, by default, set SketchUp full screen on the monitor SU window is associated to or the most present to. Update AMS Library to version 3.1.4 and the feature should work.
                      I also added the feature to set SU full screen on all monitors combined, though I haven't implemented it into this plugin yet. For now, to set main window full screen on all monitors, paste this command into the Ruby Console:
                      AMS::Sketchup.switch_full_screen(true, 2, 2)
                      See documentation of this function for more details.
                      • DimaV83D Offline
                        DimaV83
                        Thanks! It works fine, checked on each of 3 screens (across 2 video cards).
                        (I have screens with different resolution and orientation, so full-screen across all of them will not be usable in my case)
                          perroloco2000
                          Hello
                          Everytime I try to hide menu bar with AMS Windows Settings crash my SU 2016
                          I´m using AMS Window Setting 4.2.0 and AMS Library 3.1.4 (in Win10)
                          Please help, is really useful optimize my screen when I work on the laptop
                          Thanks for your greats plugins
                          • romboutR Offline
                            rombout
                            Is there a option to use this on mac? Is the code that much different when using plugins on apple machines?
                              Pherim
                              Hello,
                              just a small thing, but I noticed that when I set Floating Toolbars to hidden, save the settings and enable "Retain on Start", only some of them are hidden after restarting Sketchup.
                                Anton_S
                                @Rombout Currently this plugin is only workable on Windows. Mac OS X API is too different from Windows API. And I don't mean SketchUp Ruby API.
                                @Pherim Thanks for your report. I will get it fixed soon.
                                • romboutR Offline
                                  rombout
                                  Okay thanks for answering, I've found a working solution now which hides all panels
                                    lionk
                                    hi @Anton_S,
                                    the plugin dialog covered the trays in sketchup 2016. How to use the plugin correctly?
                                      Anton_S
                                      Left-click on the title bar of the settings dialog, hold the mouse button down, and drag it to any desired position on screen, where it doesn't intersect the other dialogs. You can also click on the x button to close it.
                                        sarkarshomit
                                        The plugin is crashing with this warning:
                                        Error Loading File C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb
                                        Error: #<NameError: uninitialized constant AMS::Timer>
                                        C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb:69:in init' C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb:572:in <top (required)>'
                                        C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in load'
                                        C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:80:in register_extension' C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:80:in module:WindowSettings'
                                        C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:62:in `<top (required)>'
                                        I had this working before on my SU16, but now after i updated it is crashing unfortunately 😞
                                        PS: I am on Win7Ult 64bit
                                        Explorer V9
                                        PS PS: I had a backup of the older working version which i copy pasted and now it works, but am scared to update!!!
                                          Anton_S
                                          Sarkarshomit, have you upgraded to AMS Library 3.3.0, besides just upgrading the Windows Settings plugin? Because if you haven't, then the AMS Timer error could be depicted due to an old version of AMS Library.
                                            sarkarshomit
                                            Yes Anton, updated today the libraries...still this error...
                                            C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb:62:in init' C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings/main.rb:562:in <top (required)>'
                                            C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:48:in register_extension' C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:48:in module:WindowSettings'
                                            C:/Users/VD/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/ams_WindowSettings.rb:34:in `<top (required)>'
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 10 / 15
