    SU scene not matching LO scene
    layout
    5 Posts 3 Posters 870 Views 3 Watching
    • sfto1S Offline
      sfto1
      The scenes in Layout 2015 are not matching the scenes I see in Sketchup 2015. I applied a color to the reverse face in sketchup so when I do an ortho projection for a plan the walls are colored. When I get to LO, the floor which is in a group below my walls show up in the walls. See attached pictures.
      Any idea of why?
      As seen in LO 2015
      As seen in SU 2015
      • sfto1S Offline
        sfto1
        I moved the floor group away from the wall group by 1/16" and that solved it for the time being. I didn't think that two separately grouped items would have z fighting issues.
          sonder
          If you have them on different layers, it is easy to set which layer is above the other layer. If they are in the same layer use the "Arrange" option to either bring the scene to the front or back.
          • sfto1S Offline
            sfto1
            Sonder,
            I will try that and report back.
              Charlie__V
              Yes, Z fighting will occur regardless of layer/group/component.
              TIG has a plugin that creates a section cut "face".
              That is what I,and many others use create a plan like the one you show.
              sorry..don't have a link to TIG's plugin
              edit:
              http://sketchucation.com/pluginstore?pln=SectionCutFace
              C
