    How to delete a model imported from *.dae file by ruby.
    4 Posts 3 Posters 814 Views 3 Watching
    • Y Offline
      yuyuwhy
      I have many *.dae files (about 10 thousand) that must be purged in SketchUp. So I write a plugin to deal with the *.dae files. How to delete a imported model in ruby?
      Here is my ruby scripts, but the code doesn't have any effects.
      model = Sketchup.active_model
      entities = model.active_entities
      entities.each { |singleEntity|
      entities.erase_entities singleEntity
        driven
        what are you actually doing?
        open new drawing...
        import dae, purge, export purged dae...
        2.times{Sketchup.send_action('editUndo;')}
        start again...
        maybe you don't even need the 2.times....
        • Y Offline
          yuyuwhy
          open new drawing...
          start again...
          yes, I just need to keep repeating the process: import a dae , purge, export purged dae, and deal with the next dae.
          thank you very much...
          πŸ‘
          • TIGT Online
            Start off by clearing everything, by using:
            model = Sketchup.active_model model.entities.clear!
            then purge the model using:
            model.definitions.purge_unused model.active_layer=model.layers[0]; model.layers.purge_unused model.materials.current=nil; model.materials.purge_unused model.styles.purge_unused ds = model.attribute_dictionaries; ds.to_a.each{|d| ds.delete(d) } if ds
            Now you have an empty SKP.
            Try doing the import AND export within a model.start_operation(...) block, BUT do not ' commit' it, rather you need to ' abort' it after each one.
            That way the import happens, the export happens but the changes to the model are undone by each ' abort'. The exported file is NOT undone by the ' abort' !
