    Fransworth House
    19 Posts 8 Posters 1.3k Views 8 Watching
    • I Offline
      imabzeous
      Model From 3D ware house by Roquemar Beltran.
      terrain modeled by me. i tried to make a desert,
      rendered in vray for sketchup.
      1: Clay render
      http://i.imgur.com/eU56J03.jpg
      • I Offline
        imabzeous
        i just remember that i haven't mailed the render image :l will update in the morning.
        • hellnbakH Offline
          hellnbak
          Wow! I hate it when people post images too small to really see anything, but this thing is HUGE! Probably the largest I've ever seen here on the forums. You might want to scale it back just a tad πŸ˜‰
          • DanielD Offline
            Daniel
            I was always under the impression the Farnsworth House used glazing for the exterior walls.
            It's obvious you're using the same plant components again and again - the same orientation and size. Try randomly rotating and rescaling them to give the appearance of variety.
            My avatar is an anachronism.
            • soloS Offline
              Fransworth house? is this the desert version of Farnsworth house?
              • pbacotP Offline
                Looks like a miniature in sand dunes at the beach. Looking good. Like the miniature Huskies too. We have huskies.
                • I Offline
                  imranbangash
                  2nd Rendered view original resolution was 6000 X 4800
                  i wanted to test my new pc πŸ˜„
                  [url][URL=http://s738.photobucket.com/user/imabzeous/media/Desertfinalkafinal.png.html]
                  http://i738.photobucket.com/albums/xx22/imabzeous/Desertfinalkafinal.png
                  [/url][/url]
                  • I Offline
                    imranbangash
                    sorry for HIGH resolution was testing my new pc and some new methods of rendering
                    First Image was Clay Render.
                    Yes Inspired from classic Disney movie The Legend of Lobo .
                    Thank you
                    • I Offline
                      imabzeous
                      Rendered Image
                      Original resolution was 6000 X 4800
                      I uploaded 2400 X 1920 but dont know why photobucket is showing it 1024 X 819 😞
                      • I Offline
                        imabzeous
                        Sorry For the HUGE image πŸ˜„ was testing my new pc and some new settings i learned recently.
                        that was clay render, and yes agreed with u on the plant component, actually i was trying to use fur plugin to generate it but i dont know why it wont place the vray proxies on the terrain , always elevated and away from terrain. 😞
                        Yes inspired from Disney's Classic The Legend of Lobo .
                        Thank you
                        • I Offline
                          imabzeous
                          Raw Render.. plz comment on my post production too.
                          • Rich O BrienR Online
                            I would recommend adding variation to the orientation and size of the vegetation.
                            The groundcover textures needs to be larger res and not as noticably tiled.
                            Maybe adjust the image cropping to respect the rule of thirds? For some reason my eye ends up looking at the grass in the foreground or the hill in the background. The house is not taking precedence.
                            I like the concept though.
                            • I Offline
                              imabzeous
                              Thanks for the tips brien, will surely change the texture and plants. and i scale down the house πŸ˜„ thats why.. am gona use wood texture next instead of white color. lets see
                              • majidM Offline
                                majid
                                Plant are huge.
                                If you want to prevent repetition, you may use 2 diffuse layer over each other and then add a transparency to the upper layer, maybe using "Tex_Noise" or simillar textures. here is a sample material, while you may replace your own textures.
                                Material1.zip
                                • I Offline
                                  imabzeous
                                  I adjust the textures and grass. here is re render.. comments and criticism are welcome.
                                  http://i.imgur.com/GLUltnE.jpg
                                  • I Offline
                                    imabzeous
                                    The original raw render was with out tall grass, i overlay the previous render with this one and get this result
                                    • hellnbakH Offline
                                      hellnbak
                                      Some things that I noticed -
                                      One of the Huskies looks like it's about to fall over. Repositioning the legs gives it a more natural stance
                                      Repeating a major object (the tree) is very noticeable. Messing around with it a bit and repositioning some of the branches helps
                                      The top steps look like they are floating, they don't connect to the lower deck.
                                      A quick and dirty shot with my suggestions
                                      • DanielD Offline
                                        Daniel
                                        Those are some big-ass rabbits.
                                        You appear to have the rendering part down, but need to work some more on the composition.
                                          Your background image is being used incorrectly.
                                          You can see the distortion.
