    Components to Groups
    15 Posts 5 Posters 1.0k Views 5 Watching
    • BoxB
      Here it is
      http://sketchucation.com/forums/viewtopic.php?p=140679#p140679
      but not much use to you as it seems to only convert one at a time.
      And just to be clearer on my comment above.
      If you select a bunch of components you can go to the component browser and 'Replace Selected' so that bunch of unique components become instances of one component. Then purge unused and you have reduced your pallet of components by that number.
      • panixiaP
        panixia
        that's fine, but he says he can't browse the components palette..
        i find that in this circumstances thomthom's "component dropper" plugin is way more reliable and fast than the native "replace selected"
        • BoxB
          His comment mentioning that hadn't been moderated before I replied and I believe you mean Component Replacer.
          • panixiaP
            panixia
            i actually use component dropper http://sketchucation.com/forums/viewtopic.php?t=26008 did'nt know component replacer.. ill'search it..
            • BoxB
              Same one, only the names have been changed to protect the innocent.
              If you click the download button on that thread it takes you to replacer.
              • panixiaP
                panixia
                also if you want (i'm not sure why) all of the component to be turned in groups, after running component dropper you could select all the geometry inside the replaced component and then explode all the parents components.. sorry for my bad english
                  ssdavis75
                  I appreciate the feedback. I'll play around. Just so you can have a better idea of what I'm dealing with, the model is of all the structural steel elements of a building, so we've got a few hundred beams (of various sizes) and several hundred bolts (of various types) and other tiny details--each being treated as a single, unique component. Going through one item at a time isn't a reasonable option, unfortunately.
                  When we consider that what makes a component a component is an association, you'd think there'd be a relatively straight-forward way to just remove that association while keeping the geometry.
                  Anyway, thanks again!
                  • BoxB
                    Use have a go with Thomthoms Component Comparison to find and replace matching geometry.
                    http://sketchucation.com/pluginstore?pln=tt_cc
                    It's not without it's problems, but it may get you to a workable stage.
                      ssdavis75
                      I'd have no problem is SU would simply interpret the DWG geometry as groups instead of components. I sent a PM to TIG to see if he had any thoughts on the topic. I believe that once upon a time SU did in fact treat DWG geometry as groups.
                      • F
                        frenccw
                        Hi, did you manage to solve your issue? I am facing a similar dilemma and hoping to find a solution. Thanks!
