    [Plugin] Solid Inspector
    303 Posts 99 Posters 260.2k Views 98 Watching
      Oh! ... I might have found the source of the problem. I wasn't seeing it because I'm working in a major update to Solid Inspector where this issues is fixed.
      I'll upload patches soon.
        I've made an update of Solid Inspector that should ensure it loads properly. Live in the Plugin Store. Should be live on EW shortly.
          d12dozr
          Thank you, TT. That seems to have solved it for me.
          http://goo.gl/f7ooYh
            magazines
            Yep, that did the trick! Thanks much.
              Jim
              Here's my crazy idea for solid inspector.
              Solid Inspector is a Tool, so you need to have it active to see the problem geometry. But then when you try to fix it using the standard SketchUp tools, the Solid Tools indicators drop out.
              So long ago I wrote a toy that cycled a material color. How about marking the problems with a animated material? Then when you drop into the normal SketchUp tools to repair the model, you can still see the problems?
                I like that idea - though it would flood the undo-stack, making it impossible to undo anything.
                In the upcoming update to SI I've added a way to select the entities for the errors found. I could expand that to a function that will apply a material to all "error-entities". Won't have as string attention effect as flashing material, but at least it will make it visible and one can use Select by Material etc.
                • jgbJ Offline
                  jgb
                  I like that idea!!!!!
                  jgb
                  • KrisidiousK Offline
                    Krisidious
                    had issues with this little group... could not get it to complete.
                    Group_109.skp
                    By: Kristoff Rand
                      Krisidious
                      Here's the "solution" I came to which still brings up a reversed face.
                      Group_110.skp
                      By: Kristoff Rand
                        I have an update that is ready very soon. Both models was handled correctly with the update.
                          Krisidious
                          By: Kristoff Rand
                            Version 2.2.1 is now available in the Plugin Store and Extension Warehouse.
                              Krisidious
                              Used it on this group and it worked except when it came to the 11 reversed faces. it left 3 faces reversed and when I went to manually flip them I noticed there were 4 reversed faces and not just 3.
                              Group_111.skp
                              By: Kristoff Rand
                                When I opened that file I visually saw 4 reversed faces - and SI detected 4.
                                Where are the 11 you talked about? Different model?
                                  Krisidious
                                  Yes, this model is after I fixed the 11... I had already saved and didn't bother undoing back before it. sorry. I got 3 on mine with new version. strange. But I didn't restart SU after install? Not a big deal to me though.
                                  By: Kristoff Rand
                                    Can you reproduce it?
                                    If you didn't restart after updating you might be still have been using the old version.
                                      Krisidious
                                      after restarting SU I get this... 😄
                                      By: Kristoff Rand
                                      • jgbJ Offline
                                        jgb
                                        I don't know if something ain't right or what....
                                        I really like the improved SI over what I had been using in SU 8 for years.
                                        I'm now on SU-15.
                                        But I just noticed that the found errors are not highlighted with big red/yellow circles. Up until yesterday, that was not a problem, as SI fixed 100% of my errors. 👍 👍 👍
                                        But then there was a new error (can't remember exactly what) that only offered info and no fix. The problem was the line was so tiny, even in red, that it took me about an hour to find it in an object with over 4,000 lines. Only by zooming in and going over the whole thing twice (2 separate but identical errors) did I find the tiny red lines, deleting them, and all was OK.
                                        No red circle to guide me to the errors. Why?
                                        jgb
                                          Did you not see a label in the viewport pointing to the edge?
                                          (got sample model or screenshot?)
                                          • jgbJ Offline
                                            jgb
                                            I do not recall seeing anything other than the warnings box.
                                            I will try to set up a "fail" and see if I get that same error message, or see a viewport.
                                            Stay tuned......
                                            10 min later ====================
                                            Well I did not get the same error msg with this test, but I got an error msg without a circle or a "viewport" pointing me to where the error was, in this case an external face.
                                            It is at the top center of the comp.
                                            Unless I zoomed in, I would not see where it was, especially if it were much smaller.
                                            The error is hard to find without a red circle.
                                            Can't see the error!
                                            jgb
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 16 / 16
