    [Plugin] Solid Inspector
    303 Posts 99 Posters 342.4k Views 98 Watching
    • BoxB Offline
      Yeah we can try, but I'm about to transplant myself across the world so may not be around much over the next few weeks.
      • E Offline
        Extractor
        Same problem here (Win7 64, SU2015 64). Just as Box describes it: When using BS Solid Inspector disappears.
          d12dozr
          Same problem for me. Win 8.1, 64 bit, SU 2015. Disabling Bezier Surface allows me to use Solid Inspector.
          http://goo.gl/f7ooYh
            magazines
            I was away for a couple of days, sorry for not keeping up. Just to say, I do not have TT_menu installed but do have bezier surface. My problem persists with solid inspector in su14 but not su15.
            It's a great plugin, I'm not totally ready to switch everything to Su15 yet, so if there is anything I can try just tell me.
              Oh! ... I might have found the source of the problem. I wasn't seeing it because I'm working in a major update to Solid Inspector where this issues is fixed.
              I'll upload patches soon.
                I've made an update of Solid Inspector that should ensure it loads properly. Live in the Plugin Store. Should be live on EW shortly.
                  d12dozr
                  Thank you, TT. That seems to have solved it for me.
                    magazines
                    Yep, that did the trick! Thanks much.
                      Jim
                      Here's my crazy idea for solid inspector.
                      Solid Inspector is a Tool, so you need to have it active to see the problem geometry. But then when you try to fix it using the standard SketchUp tools, the Solid Tools indicators drop out.
                      So long ago I wrote a toy that cycled a material color. How about marking the problems with a animated material? Then when you drop into the normal SketchUp tools to repair the model, you can still see the problems?
                        I like that idea - though it would flood the undo-stack, making it impossible to undo anything.
                        In the upcoming update to SI I've added a way to select the entities for the errors found. I could expand that to a function that will apply a material to all "error-entities". Won't have as string attention effect as flashing material, but at least it will make it visible and one can use Select by Material etc.
                        • jgbJ Offline
                          jgb
                          I like that idea!!!!!
                          jgb
                          • KrisidiousK Offline
                            Krisidious
                            had issues with this little group... could not get it to complete.
                            Group_109.skp
                            By: Kristoff Rand
                              Krisidious
                              Here's the "solution" I came to which still brings up a reversed face.
                              Group_110.skp
                              By: Kristoff Rand
                                I have an update that is ready very soon. Both models was handled correctly with the update.
                                  Krisidious
                                  πŸ‘
                                  By: Kristoff Rand
                                    Version 2.2.1 is now available in the Plugin Store and Extension Warehouse.
                                      Krisidious
                                      Used it on this group and it worked except when it came to the 11 reversed faces. it left 3 faces reversed and when I went to manually flip them I noticed there were 4 reversed faces and not just 3.
                                      Group_111.skp
                                      By: Kristoff Rand
                                        When I opened that file I visually saw 4 reversed faces - and SI detected 4.
                                        Where are the 11 you talked about? Different model?
                                          Krisidious
                                          Yes, this model is after I fixed the 11... I had already saved and didn't bother undoing back before it. sorry. I got 3 on mine with new version. strange. But I didn't restart SU after install? Not a big deal to me though.
                                          By: Kristoff Rand
                                            Can you reproduce it?
                                            If you didn't restart after updating you might be still have been using the old version.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
