    [proto] 2d stencil - real line hatches
    27 Posts 11 Posters 10.0k Views 11 Watching
    • K
      kaas
      Hi Jolran,
      In earlier versions of the plugin I did manually use your 2dBoolean afterwards because the plugin only did the hatching. In the newer versions, I added code to do the intersections immediately after the copy-ing process so 2dBoolean isn't needed anymore. The workflow got more streamlined by doing so.
      It's quite fast until you copy/array more than 50k to 100k edges in one go. At that moment Ruby slows down fast.
      edit: you can see how many copies & edges are generated at each pattern-fill by reading the messages on the status bar (bottom left)
      edit2: but your 2dBoolean code was better. This one needs extra code to handle 'surfaces with islands' (a wall with a window + brick pattern = bad results at the moment).
      • jolranJ
        jolran
        Ah, I see.
        Your code seems to be working fine though.
        I don't get same timings on my computer. 25k is already taking over a minute to intersect. So in my computer in order to achieve a "smooth" workflow as a stamptool I would estimate components shouldn't rise above 10K. ❓
        50K -100K really sounds a lot. But I'm getting the impression my computer is getting old..
        Like I said in another topic, it would be interesting to see what kind of response time different workstations get from intersections like this. And using edge-patterns in LO.
        Although that line patterns would never really become dense(?) and cause a problem, but does indeed look very useful.
          julyyen
          Hi and a happy new year,
          It is possible to offer your plugin as a free download because I look for centuries to find a good insulation hatch, the others seems fine too, please?
          • K
            kaas
            @julyyen said:
            ..It is possible to offer your plugin as a free download because I look for centuries to find a good insulation hatch...
            If you're just looking for the hatch, I attached the skp file.
            isolatie2.skp
              julyyen
              Thank you very much, I don't know how to make a texture from the file and the most important thing is that I want the texture to automatically fit on a surface, when applied.
              That's the reason why I (and possible, others like me) hope to kindly share this plugin with us maybe in the future, if not, we're out of luck.(even with that nasty 😑 bugs)
              • K
                kaas
                @julyyen said:
                ...and the most important thing is that I want the texture to automatically fit on a surface, when applied...
                the thing is: this is a plugin that doesn't use textures but uses real edges(lines) instead. If you want a solution that uses textures you have to look elsewhere (Skalp for instance)
                • K
                  kaas
                  update: added some features. See new video in first post.
                  • KrisidiousK
                    Krisidious
                    Nice Kaas... I'll be watching.
                    By: Kristoff Rand
                    • jujuJ
                      juju
                      Nice going there, a few questions:
                      • are the hatches editable once applied?
                      • can one "explode" the hatch/fill to the surface to have it intersect the surface (thinking of quick flagstone, and the like, creation)?
                      • K
                        kaas
                        @JuJu:
                        1. the hatches are just grouped lines / edges. They have no special properties so you can do with them whatever you like.
                        2. yes, you can explode them and use them as a cookie-cutter to cut a face. Although, if the pattern is very complex, it doesn't always go right and Sketchup needs some re-tracing some of the edges but I did use it to cut and color a mosaic floor for instance (see image).
                        • JQLJ
                          JQL
                          This is becoming an almost must have tool! Also looking forward to it
                          www.casca.pt
                          Visit us on facebook!
                          • P
                            pibuz
                            Following with interest! Great addon!
                            WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                            • F
                              function
                              looking forward to hatch blasting with this one πŸ‘
                              • U
                                unearthed
                                Hi Kaas, Great plugin, really, really useful - I really hope you're able to make a SU 8 version.
                                Growplan - People ∩ Plants ∩ Place
                                windows 7 64b, 4GB RAM, SU 8.0.16846
                                Gimp, QGIS, Vectorworks 12, Bricscad 11
                                • JClementsJ
                                  JClements
                                  Would it be an improvement to save the hatching element as a component rather than a group so that the file size is smaller?
                                  • K
                                    kaas
                                    I didn't go that route with this version because the plugin was initially made from a hatching-sections point of view. That involves lots of cutting of the hatches after the copy process so a lot of the components would have to be exploded.
                                    I do see the benefits using components for 2d elements that wouldn't have to be cut. Stuff like: cars, trees, furniture, plants etc etc. Someone also suggested if it could be done with glue/cut-components. I will have a look if this can be implemented.
                                    • F
                                      function
                                      I do like the idea of using this as a component or block library. I always have found then native component window clunky for setting up my libraries
                                      • JQLJ
                                        JQL
                                        πŸ‘
                                        www.casca.pt
                                        • P
                                          penaten
                                          Looks like over a years worth of non activity. Any further progress? Looks like a very useful concept. Is it downloadable?
                                          • K
                                            kaas
                                            I stopped development in feb 2015 (see my 'edit' in the original post). Maybe at some point I will pick it up again (with the help of a proper coder) - it was my first ruby plugin and needs a complete overhaul. At that point it would be a payed plugin so the current code is not downloadable.
