    Sketchup icon does not shows in Mac finder.
    32 Posts 6 Posters 5.4k Views 6 Watching
      driven
      @jeff hammond said:
      ...with the view of the model when the file is saved/closed being the icon view. rhino works like that and it's pretty sweet.
      mine can be very easily modified to do that, but it's something I didn't want...
      the main reason was I always save the document based on what I just drew, which might not represent the model very well.
      I think of them more like a poster-frame on a .mov where you frame what you want and apply it as an icon.
      an on-close overwrite would take away my choice...
      Trimble have two engines that they could exploit for better previews...
      one is Apples DAE quicklook generator
      the other is the system used for 3d Warehouse that could be hosted locally and feed the html to quicklook...
      I would image either solution will only be explored if windows has similar possibilities...
        slbaumgartner
        In case any Mac users were following this topic and wondered why I was getting that icon, I found the answer: when two apps both register for the same file UTI, Finder uses the icon for the most recently installed one. I had installed SketchUp 2015 on Windows in Parallels and let Parallels make it visible in Mac mode. I did this after installing the native Mac version, so Finder chose the Windows icon. Touching the native Mac app to give it a more recent timestamp fixed the problem.
        Steve
          amarv91
          @driven said:
          @amarv91, can you see the icon from the zipped skp I posted?
          @jeff, cheers
          @steve. that is odd, it's certainly not a windows generated skp...
          what does
          xattr -l <path_to_file>
          show for that file...
          I'll see if I can find how I fixed it when I used Parallels, I did have that issue at some stage.
          Hi John,
          Below are the icon preview in different views.
          v1
          v2
          v3
          v4
          It shows in all views except in thumbnail....! πŸ˜•
          Cant figure out why....
          Amar
            driven
            the icon created by my plugin shows up in all views...
            I'll PM you a copy if you want...
            • jeff hammondJ Offline
              Amar
              yeah, weird indeed. (I don't know why it's doing that nor have I seen the behavior before) πŸ˜•
                driven
                @amarv91 said:
                ...Below are the icon preview in different views...
                do they show if you adjust icon size?
                Icon size: Use this slider to dynamically adjust the size of the icons in this folder. The larger the icon, the easier it is to see the thumbnail previews. Of course the larger they are, the more room they take up.
                and, did you reset Finder?
                  amarv91
                  Yes using slider shows the icon, but only if it is above 128px X 128px.
                  I tried resetting the finder. (i.e relaunching the finder)
                  And ya please share the plugin which u have...
                  Amar
                    driven
                    @Amar,
                    I'll PM you a rbz...
                      joemed
                      I wanted to see if there was an update on the Icon status for Mac’s
                      Many of my older files created with Sketchup 8 Pro have a custom icons.
                      Once opened in Sketchup 2015 Pro and saved as 2015 or Sketchup 8 they only have generic icons.
                      Is there a plugin or secondary solution?
                      Thanks in advance.
                      Joe
                      MBP i5 2.53 GHz 8GB Mavericks 10.9.5
                        do you mean generic like the problem in the original post or generic like this:
                        one is a problem and one is just trimble not providing the proper programming πŸ˜‰
                        fwiw, i recently had a similar problem as the original post only with my webloc icons.. 'fixed' it like so:
                        go to
                        ~/Library and drag the Caches folder to the desktop (just in case.. move it to the trash eventually)
                        reboot computer
                        go to
                        Macintosh HD/Library and drag the Caches folder to the desktop.
                        reboot computer
                        after that, the webloc icons showed their stuff again instead of the blank white.
                          grayartist
                          I'm having the same trouble with the icons showing only a blank page. I just updated my system to Yosemite, and have regretted every second of it due to all the programing issues it seems to have with every program I use. I upgraded mainly because I use Podium and the newest version of Podium Walker only functioned for Yosemite.
                          I'm very illiterate when it comes to programing jargon. What ended up being the fix for this?
                          • 2 / 2
