    Firing Button with Modifier Key
    11 Posts 6 Posters 1.1k Views 6 Watching
    • CadFatherC Offline
      CadFather
      does anyone know: Can a toolbar button be aware of a modifier key being present (pressed)?
      i can see it is possible with mouse click, but not from toolbar (at least all my attempts have failed).
        I don't think it is possible. 😞
        I've never managed it - so it is probably impossible πŸ˜‰
          CadFather
          wow TIG, not even you! really hope some trimble folks start looking at this whole universe!
          what of a process like this: click button > script looks to see whether any key is pressed > if within 1 sec no modifier is found > go ahead with the main routine > else...
          dreamland?
            I guess you could hook into the Win32 API (not sure what you got under OSX for that) and detect key presses.
            Though, it'd be very unconventional UI - don't think I've seen any applications that has modifier keys for toolbar actions.
              CadFather
              thanks Thomas, so a ruby script cannot simply 'listen' to key press upon firing?
              PS (never mind macs!) πŸ˜‰
                If you hook into the Win32 API I think it should be possible. But I have no simple examples of that. Anton might know more - think he's doing something like that for his full screen extension.
                  You could probably also write an AutoHotKeys snippet [PC only!] which would spot a click in SketchUp with a key etc, BUT it'd be mucho complicado... πŸ˜’
                    driven
                    if the button you click is a tool, you can watch for modifier keys?
                    I assume [due to lack of use case] that you want one button for 3 tools [as example]...
                    create a simple tool with one button...
                    on click, [activating your tool] start a timer and watch for modifier keys...
                    if key = a activate x
                    if key = b activate y
                    if you run out of time if activate z
                    is that the sort of thing your after?
                    or have I completely misunderstood yet again...
                      Jim
                      There's this, but Windows only and not up-to-date and needs compiled, etc.
                      https://code.google.com/p/eventrelay/
                        Anton_S
                        There is a way, thought it will require that your extension to require AMS Library. Easy to implement.
                        Here is a snippet:
                        require 'ams_Lib/main'
                        class MyTool
                          def swp_on_key_down(key, val, char)
                            # process...
                            # Return 1 to prevent key from interacting with SU window.
                            # Return anything else to avoid blocking the key.
                        AMS;;Sketchup.add_observer(MyTool.new)
                        Here is the docs for all events you can use: AMS::SketchupObserver
                        You can monitor/process keyboard press, mouse clicks, and even the mouse wheel rotate/tilt.
                        Windows only!
                          CadFather
                          didn't notice the thread had progressed...
                          ahk is quite good, i can see it possible but not too good for public consumption - with compatibility etc..
                          yes, exactly that.
                          will have a look, thanks Jim
                          Here is a snippet:
                          very interesting Anton, will look into it
                          (where's a Christmas holiday when you need it?!)
