    OSB lamp
    21 Posts 8 Posters 1.3k Views 8 Watching
    • hellnbakH Offline
      hellnbak
      Very nice work!
      One question - how do you get all those rings thru the legs?
      • BoxB Offline
        I'm sure Cotty used a method not unlike this.
        http://i155.photobucket.com/albums/s296/storeben/SU/Cotty.gif
        • hellnbakH Offline
          hellnbak
          Thanks, Box, but I meant how was it done when building the real thing.
          • BoxB Offline
            Ah, ok, Sorry about that, must admit I was a surprised by your question, but now see what you meant.
            • Bryan KB Offline
              Very nice!
              I like the SkecthUp style as well.
              • jeff hammondJ Offline
                @hellnbak said:
                Very nice work!
                i think it's actually do-able.
                the rings would be split at one point around the circumference.
                bend them open a bit..
                slide all the legs on the rings.
                put the horizontal piece in the leg slots..
                spin the legs around the circle into position..
                the ring seam is hidden inside one of the legs.
                looks good @carsten.. really liking the osb texturing πŸ‘
                • cottyC Offline
                  cotty
                  @Hellnbak:
                  I didn't thought about the real thing, but maybe Jeffs solution would be the best to try.
                  @Box:
                  I thought about creating a short making of, but what can I add to a classical BoxGIF? πŸ˜‰
                  @Jeff: Thank you, I will prepare the model for sharing ans will include that texture...
                  @Bryan: I've used a rendered clay image with relatively high transparency setting and overlayed it with a line export from SU to generate the effect.
                  Thanks again for your comments!
                  my SketchUp gallery
                  • hellnbakH Offline
                    hellnbak
                    Actually, if I had bothered to click on the link Cotty provided I would have seen that the original used black rubber cords
                    not nearly as attractive as Cotty's variation
                    And Jeff's clever idea would probably work.
                    • BoxB Offline
                      I didn't mention that I like the lamp a lot, very nice.
                      It was early in the morning here, bloody hot, which I'm not used to any more and so hadn't slept well, I wasn't thinking straight.
                      I was honestly dumbfounded by what I thought was hellnbak managing to make his amazing models without knowing how to do a multi array, D'oh. I totally missed the point.
                      So give mine the flick and do a nice making of yourself.
                      • cottyC Offline
                        cotty
                        I've added a link to the page with the download button ("Herunterladen") to the first post.
                        my SketchUp gallery
                        • leedeeteeL Offline
                          leedeetee
                          Just a quick question if I may, on that example, what is the process after using the follow me on the 'leg' to getting the 6 wires?
                          Nice lamp by the way!
                            see this post:
                            http://sketchucation.com/forums/viewtopic.php?p=543947#p543947
                            (and notice in box's example in this thread, there's a bit of Z-fighting on the leg.. he has the leg as a component but there's also a single face outside of the component which is what's actually being swept.. in a manner similar to what's shown in the link)
                            • BoxB Offline
                              Well spotted there Jeffrey, I opened the leg component and copied the face then closed it and paste in place. Since the edge of the face was one wielded edge it was one click and delete to remove the excess after the follow me.
                              • hellnbakH Offline
                                hellnbak
                                A variation on your model
                                Tried it with a lampshade but it just didn't seem to work πŸ˜†
                                yeah, I'm bored πŸ˜’
                                  Camp fire revival! πŸ˜„
                                  • cottyC Offline
                                    cotty
                                    πŸ˜„
                                    my SketchUp gallery
                                    • DanielD Offline
                                      Daniel
                                      @jeff hammond said:
                                      @hellnbak said:
                                      Very nice work!
                                      Or, the holes in the legs do not go all the way through, and the rings are actually individual curved rods between the legs. Given how thick the legs are, and how tight the holes are, it might be hard to slide the legs around the rings.
                                      Nice model and rendering, Cotty. I think your design looks better than the original.
                                      My avatar is an anachronism.
                                      • hellnbakH Offline
                                        hellnbak
                                        But wouldn't assembly of all those parts be very difficult?2015-01-02_135548.png
                                        The legs would have to be fastened to the base first, and, as you said, they are very thick, so there would be no flexing them to install the rods.
                                        • DanielD Offline
                                          Daniel
                                          The tricky part would be the last leg and the rings on either side of it. but it could probably be done by a dexterous person with practice. Hell, there is probably a machine that can do it.
                                          • cottyC Offline
                                            cotty
                                            In some years, we will use a 4 components 3D printer (wood, rings, bulb, cables) to create things like this in one go πŸ˜‰
                                            my SketchUp gallery
