    PLZ HELP! Sketchup 2015: is not a valid W32application
    8 Posts 3 Posters 5.1k Views 3 Watching
      leetran72
      After i installed vray for sketchup 2015 (x64) I open sketchup and if appered this messages. Please help me to fix this problem. Sory my English not very well, so I can't say much! 😞
      Error Loading File C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/vfs.rb
      Error: #<LoadError: 193: %1 is not a valid Win32 application. - C:/Users/Slim/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/RubyWinFunc.so>
      C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
      C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/vfs.rb:25:in getWindowsASGVISFolder' C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/vfs.rb:45:in getASGVISRubyFolder'
      C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/vfs.rb:50:in setupPath' C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/vfs.rb:79:in <top (required)>'
      C:/Users/Slim/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_vray_tools/core.rb:59:in require' C:/Users/Slim/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_vray_tools/core.rb:59:in block in module:VRayTools'
      C:/Users/Slim/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_vray_tools/core.rb:56:in each' C:/Users/Slim/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_vray_tools/core.rb:56:in module:VRayTools'
      C:/Users/Slim/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_vray_tools/core.rb:33:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
      C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Slim/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_vray_tools.rb:40:in register_extension'
      C:/Users/Slim/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_vray_tools.rb:40:in <module:VRayTools>' C:/Users/Slim/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_vray_tools.rb:15:in module:Plugins'
      C:/Users/Slim/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_vray_tools.rb:14:in <module:TT>' C:/Users/Slim/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_vray_tools.rb:13:in <top (required)>'
      Error Loading File vfs.rb
        You now have the 64 bit version of SketchUp v2015.
        A few Plugins are not yet compatible with the 64 bit version - specifically those which use 'system' .so files etc, where they were originally made for 32 bit, and are therefore incompatible...
        Your current version of 'Vray' - C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/vfs.rb is I suspect one of those... when trying to load C:/Users/Slim/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/RubyWinFunc.so
        If you have the 'SketchUcation Toolset' you can use its 'Plugins Manager' to 'Disable' the ' vfs' loader - it renames it vfs.rb! so that it no longer auto-loads as SketchUp starts...
        If you don't have the 'SketchUcation Toolset' 'Plugins Manager' you can always rename the file manually...
        You must restart SketchUp to see the changes...
        Authors are aware of the issues with their Plugins under 64 bit...
        Luckily for you 'Vray' have recently issued an update [SP3] to give 64 bit compatibility - see here
        http://www.vray.com/vray-for-sketchup/
        Obviously you'll need to download it and then update/reinstall 'Vray' to avoid these SketchUp load-errors...
        But meanwhile disabling ' vfs' will stop the errors... 🤓
          leetran72
          Thank guy for support me!
          But how can I using Vray while disbaling vfs? 😞
          Every another things work fine, except Vray (I'm using latest vray version for SU2015, for sure I'm using 64bit version!
            If you have the latest version of Vray 2 with the SP3, then it should give 64 bit support...
            if not, then need to update it to be compatible with 64 bit - use the link I provided...
            If you have updated and still have issues, then contact Vray...
            Older versions will NOT work as they are specifically for 32 bit.
            You can't use Vray if 'vfs' is disabled.
            That is the file that loads to include Vray in SketchUp.
            Disabling it when the version is not compatible simply avoids startup error-messages - it doesn't load properly anyway.
            Disabling it when the version is actually compatible allows you to re-enable.load it as you need it - e.g. temporarily loading it for that session - you probably don't want Vray loaded all of the time ?
            • X Offline
              xcentric73
              I get this massage when i start sketchup.
              Error: 127: Impossível localizar o procedimento especificado. - C:/ProgramData/ASGVIS/VfS/RubyToPython.so
              C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/vfs.rb:86:in `<top (required)>'
              I installed 'SketchUcation Toolset' and there is no "vfs" in the 'Plugins Manager'.
              Can you help?
                @Miguel
                It's a 'message' [mensagem ?]... NOT a 'massage' which is something quite different 😲 [ 😉 ]
                Anyway, back to the problem...
                Re-read the error-message...
                Error Loading File vfs.rb Error: 127: Impossível localizar o procedimento especificado. - C:/ProgramData/ASGVIS/VfS/RubyToPython.so ... **C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins/vfs.rb**
                The VfS installer puts Plugins into the ProgramData Plugins folder NOT the main Plugins folder.
                The SketchUcation 'Plugins Manager' lists Plugins BY FOLDER.
                The initial default is the main Plugins folder.
                The top drop-down list can be changed to list the other folder...
                Now for the error...
                You SCF user-profile says you use v2014, but this error relates to v2015 - so I assume you have upgraded...
                SketchUp v2014 is 32bit.
                SketchUp v2015 can be 32 OR 64bit.
                You haven't said what your PC's OS is.
                If it's 32bit, then all programs are installed into a folder within 'Program Files', but on a 64bit system there are two folders - 'Program Files' for 64bit applications and 'Program Files (x86)' for 32bit applications.
                It's not clear from your post what you have set up, because it could be SketchUp v2015 32bit on a 32bit PC, OR SketchUp v2015 64bit on a 64bit PC - as both would use the 'Program Files' folder.
                From your error message I can see...
                C:/Program Files/SketchUp/SketchUp 2015/Tools/...
                I assume you use the matching version of Vray with SketchUp.
                So what is your SketchUp v2015 'bit' type?
                What is your Vray 'bit' type?
                There is a new 64bit compliant version out, but of course you can't install it on a 32bit system ??
                • X Offline
                  xcentric73
                  Sorry my english! 😄
                  I had this problem before. Then i format my pc and made a clean install of sketchup + vray and everything was working fine. Later, i installed Photoshop and Adobe Acrobat Pro and (do not know if because of it) in sketchup reappeared the initial error and doesn´t load vray.
                  Vray is the only plugin for sketchup i installed.
                  i´m using:
                  • Windows 7 profesional x64 Portuguese,
                  • sketchup 2015 pro - version 15.0.9350 64-bit
                  • Vray 2.00.25255 for Sketchup 2015 x64bit
                  Any ideas?
                  Thanks.
                    @Miguel
                    There is Service Pack 3 to suit v2015 64 bit, http://www.vray.com/vray-for-sketchup/buy-vray-for-sketchup.html
                    Have you these latest files installed ?
                    Have you contacted the Vray support guys ?
