    Select only top surface?
    9 Posts 3 Posters 345 Views 3 Watching
      LARV
      Is it possible to select only the top surface in this sandbox mesh without having to shift-click every face one by one?
      • BoxB Offline
        One option.
        And the fencing the other way.
          LARV
          Yes, thanks, I´m aware of that procedure, but it wouldn´t work in this attached example (should´ve posted this one in my first post I guess). Would be nice with a plugin to select every surface that was originaly facing a certain direction. The top one in this case.
          • jeff hammondJ Offline
            soften/smooth it (right click ->soften) then the top surface is selectable.
            copy it first if you need the hard lines again later. move it on top the smooth one and the lines will reappear.
            • BoxB Offline
              Easiest way is to smooth the surfaces then just select the top.
              Same time again.
                that's what she said!
                (or did I use the joke wrong? 😄 )
                  LARV
                  I smoothed the object but everything still gets selected when I click twice or three times.
                  • BoxB Offline
                    Turn off hidden geometry and click once on the top.
                    Edit> no you have over smoothed it, you want the sides to stay as hard edges.
                      LARV
                      Nice! Thank you! This will come in handy for sure.
