    File.writable? false for DOCUMENTS folder
    6 Posts 5 Posters 504 Views 5 Watching
      pgarmyn
      Ruby ALLWAYS reports "not writable" for the documents folder on my system, Windows 8.1.
      Even if i am administrator. And even if i can write in the directory.
      I suppose it is for security reasons (?)
      puts ENV["HOME"]
      #output ; # C;/Users/USERNAME
      File.writable? ENV["HOME"]
      #output ; # true
      File.exist? ENV["HOME"]+"/Documents"
      #output ; # true
      File.writable? ENV["HOME"]+"/Documents"
      #output ; # false  ## THIS IS NOT LOGIC because i can write ;
      File.exist? ENV["HOME"]+"/Documents/test"
      #output ; # false
      Dir.mkdir ENV["HOME"]+"/Documents/test"
      #output ; # 0
      #output ; # true
      File.writable? ENV["HOME"]+"/Documents/test"
      #output ; # true
      It seems that plugins must ignore this false information ?
      Can someone confirm ?
      The properties of my documents folder are.
        driven
        what does it return if you add an additional /
        puts File.writable? ENV["HOME"]+"/Documents/"
        both variants return true on a mac...
        • TIGT Online
          As you have discovered... File.writable?{file_or_folder_path) only works consistently/effectively on MACs.
          On PCs you can add a final ' /' and it might [sometimes] work... but I recommend that you really need to try to briefly write a temporary file to that folder in your own 'trapped' method, to get a consistent and 'correct' result... e.g.
          def self.writable?(directory_path=nil)
            return nil unless d=directory_path
            return nil unless File.directory?(d)
            begin
              r=rand.to_s
              r.next! while File.exist?(File.join(d, r)) #unique temp file trap
              t=File.join(d, r)
              f=File.new(t, 'w')
              f.puts("0") #it's made, can we modify it ?
              f.close
              if File.exist?(t)
                begin
                  File.delete(t)
                  w=true
                rescue #can write it BUT not change it !?
                  w=false
              else
                w=false
            rescue #can't write it at all !
              w=false
            return w
          This test is used thus self.writable?(some_directory_path), which returns true or false if a temporary file can be written to the folder, or it returns nil if no 'directory_path' was passed or the folder doesn't exist and/or it is not a directory !]...
            slbaumgartner
            Both false on my Win 8.1
            My experience is that 'Documents' is the exception on Windows.
            For other folders, the value is consistenly.
            Could this be related to the "shims" that recent versions of Windows use to fake some folders?
              pgarmyn
              My experience is that 'Documents' is the exception on Windows 8.1.
              (I don't have non ASCII cars in the path)
                Ruby's file handling under Windows is frustratingly flaky. We have reported a number of issues to the Ruby developers and I'd encourage people to file whatever you find.
                I usually wrap file handling in a begin, rescue block instead of testing if a while is writable - simply because Windows file handling is unpredictable.
