    LO2015: no scale indication @ right-click anymore
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    5 Posts 3 Posters 8.1k Views 3 Watching
    • K
      kaas
      In previous versions of LayOut, after right-clicking any SketchUp-page, you would get the current scale indicated for that element. In the right-click 'rollout' it's gone in 2015 so now you have to open the sketchup-model-tab to see the current scale. Would be nice if that old feature could be implemented again.
        marcdurant
        On Windows I see the current scale marked with a check mark and a "Current Scale" label. On mac I'm not seeing the "Current Scale" label, but there is still a check mark next to the active scale.
        If you select "1:500" in that context menu, does a check mark appear?
        • K
          kaas
          @marcdurant said:
          ...If you select "1:500" in that context menu, does a check mark appear?
          If I change the scale in the context menu, it does appear. But, after a short while, it's gone again. I haven't been able to detect any logic or pattern in it.
          To test again, I made a simple house and added some scenes. Send it to layout:
          1 changed scene from context menu,
          2 changed scale from context menu,
          3 copied the scene to another position on the paper
          4 go to step 1 + repeat
          5 after all the scenes were placed on the paper, I checked if the check marks were still there. They were gone.
          6 re-did the scaling so the checkmarks were there. saved + closed Layout. Opened layout again, the checkmarks were gone again.
          scaleCheckMarks.layout
          • pbacotP
            Same here (Mac). Just after setting the scale, it will show a check, but simply right clicking an existing scaled reference does not show a check mark at the scale.
              marcdurant
              I made an entry for this in our bug tracker, so we'll take a look at it.
              Thanks,
              Marc
