    [Proto] Generating Terrain from a Cloud of Points
    46 Posts 21 Posters 7.4k Views 21 Watching
      rodman100
      Terrain Model c.jpgThat looks good Fredo from the gif, I'm still on SU V14 so can't see your posted model but the surface looks similar to my terrain model, which from memory looked like the actual terrain. The contours can differ slightly when generated solely from points (as in my attached terrain model) as this method does not take breaklines (distinct interruption in the slope of a surface, such as a ridge, road, or stream)into account. But that depends very much on the particular site.
        You say cloud of points, but seems it's very similar of a cloth falling on volumes ?
        Maybe a cloth algorithm will be more speedy ?
        • pbacotP
          @rodman100 said:
          [attachment=0:aclpnu4d]<!-- ia0 -->Terrain Model c.jpg<!-- ia0 -->[/attachment:aclpnu4d]
          I want my models to look this nice. πŸ˜„
          • ArcA
            Arc
            see this video
            http://youtu.be/TgFYucpBBKs
            • fredo6F
              Here is the file in SU2014
              Rodman100 - survey - SU14.skp
              • fredo6F
                @arc said:
                see this video
                That's what I said. There are specialized application to treat massive volumes of points and generate heightmaps. So handling it in Sketchup is really just a convenience for very simple cases.
                • fredo6F
                  Here are additional pictures
                  • one with a Tri-mesh from the Cloud Point
                  • the other with a Quadmesh generated from the iso-contours of the tri-mesh terrain
                    mac1
                    @fredo6 said:
                    @roland joseph said:
                    I am saying for me at least generating a terrain with cloud point is not very exciting. It would be selfish to say I would rather a talent like you work on other things. πŸ˜„
                    I think that generation of terrain is an essential feature for Sketchup, not to say that making organic shapes from control points can be useful too.
                    Actually, this is not something simple to develop in Ruby, because of the lack of efficient algorithms and the variety of topological situation. So nothing straightforward in this plugin project.
                    Not by wheel house but using posted point cloud data must be predicated on high confidence the data you are using is "good". Some of the data you have used looks good visually but appears to include several data sets and some of the vertex normals questionable.You cannot tell that by using SU to just look at the data. "....You probably do not need shading so using a mesh built using Voronoi Filtering may be more useful but it needs a very clean data set to work with."
                    Ref http://meshlabstuff.blogspot.com/2009/09/meshing-point-clouds.html. I am guessing contacting them they may very well have good test case for you?
                    • utilerU
                      utiler
                      This is a super plugin, Fredo! I'll be sure to get it..... πŸŽ‰ πŸŽ‰ πŸŽ‰
                      Just Curious...
                      • fredo6F
                        Well no intention to mimic a Meshlab that can swallow 9 millions points. Instead my design goal with this plugin is to generate a surface from a few points (say a few tens or hundreds). Therefore, I am more faced to a problem of interpolation than filtering. My question and the reason I wanted to have sample model is to test interpolation algorithms.
                        By the way what is exactly Voronoi filtering (The Meshlab demos refers to Poisson disk)?
                        I do agree that the original data are important because they do influence the shape. Unfortunately, even if I wrote some part of the script in C, I don't think I can produce an interactive version where you could edit, move and delete points and see instantly the impact on the terrain.
                          mac1
                          @fredo6 said:
                          I can not give exact definition but is my understanding is the output is more of an interpolation of the input data rather than a estimation like some of the other filters. The voronoi filter is included in meash lab program and this link is rather interesting and covers how to convert the veronoi shell to a solid suitable for 3 printing http://meshlabstuff.blogspot.com/2009/04/creating-voronoi-sphere-2.html
                          • 3 / 3
