    Plugin Request: Export as .amf
    23 Posts 4 Posters 9.6k Views 4 Watching
      BallBearing
      3D printing is going ahead. It would be nice to export things as: Additive Manufacturing File Format (.amf) to store colors etc. Smaller file size?
      SketchUp, 3D printing stuff and more:
      http://www.youtube.com/user/CinemaTablet
        Jim
        Been meaning to start one. A basic exporter should not be too difficult.
        Last time I looked there was not a viewer for .amf files. I would need to view exported files to test exports. Any ideas?
          Jim
          Actually, this discussion[1] indicates the format is not widely used. What printers support it?
          [1] http://groups.google.com/forum/#!topic/stl2/PvhY0X9EHOc
            BallBearing
            The format is supported at least Slic3r 3D slice / printing program so widely sold Ultimaker printers, " hundreds" of Reprap clones etc. can use it I suppose. It is new format I think, but coming...
              Jim
              Do you have an example model? How do you think the .skp to .amf translation should work wrt Groups, Components, Colors, Materials?
                BallBearing
                I think that for 3D printing translating colors from .skp to .amf would be the most important. But http://3daddfab.com/blog/index.php?/archives/5-AMF-The-3D-Printing-Format-to-Replace-STL.html says: AMF Can Describe Materials, Compositions, Colors, Textures and More
                I don't have yet a multiple head extruder on my printer so I cannot test these files in practice, I can just load them to Cura or Slic3r to make G-code for printing. There are files at http://amf.wikispaces.com/AMF+test+files.
                Colors:
                http://amf.wikispaces.com/file/view/FaceColors.amf/268219586/FaceColors.amf
                  Jim
                  My plan is a to focus on geometry with colors. There is currently little demand for more. I hope to have some time over the next 2 weeks.
                    Jim
                    Here are some preliminary files if anyone would like to verify correctness between skp and amf.
                    amf.skp
                    ASCII .amf. Forum does not allow .amf extension. Had to rename to .txt file.
                      BallBearing
                      It seems to load, but I can't see colors in Cura (scaled one), not even on the "official" colored cube. One made in Cura "merged" amf seems to have two colors : three-amf-files-on-the-plate.png
                      In this video the file is made of two pieces (merged) and saved as amf, and loaded again, but it is a Cura thing then...or...: http://youtu.be/FKgHEO1g-S0?t=1m4s
                      I think that there is some color at the end of this:Cake dual.amf.txt It looks like that the colors are under material id. Looks like that the Cura wants materials then? I haven't tested this on other software yet.
                      <material id="1">
                      <metadata type="Name">Material 1</metadata>
                      <color><r>1.00</r><g>0.88</g><b>0.15</b></color>
                      </material>
                      <material id="2">
                      <metadata type="Name">Material 2</metadata>
                      <color><r>0.20</r><g>1.00</g><b>0.10</b></color>
                        Jim
                        Thanks - the video is very helpful. It helped clarify some of the element of the .amf files and I will be able to improve the export.
                        Unfortunately, Cura appears to ignore the unit information in the .amf file. That is disappointing because units was a problem with the .stl format that .amf was designed to fix.
                          BallBearing
                          Slic3r or Cura do not have support for inches. 0.1mm is 0.00393701". So many digits.. I don't know about other software.
                          • TIGT Online
                            Surely the whole idea of .amf is that you can pass lots of variables - like the unit size...
                            e.g.
                            <amf unit="inch" version="1.1">
                            or "m", "mm", "millimeters" etc - although there has been a lot of pressure to default to "mm" !
                            If you're looking to use a new standard that supports many laudable things - like different units - then it's a crime to ignore it in the 'so-far-few' apps that do read it !!
                            ๐Ÿ˜’
                              BallBearing
                              Well, if the units are ignored, then you just have to know, that you have to convert your work to mm for 3D printing software, for now. This problem does not stop using possible amf exporter? This is a s frontline thing now. Slic3r & Cura at least ahead now, perhaps others come soon to support amf. I'm trying to find information...
                              • TIGT Online
                                If Jim's exporter always converts the dimensions to 'mm' and puts that in the header 'unit=', then it should work just fine anyway - importers of the data will either assume it's 'mm' anyway, or use the header data and use 'mm' from that ?
                                  Jim
                                  It is astonishing that the units are being ignored in Cura. STL's lack of units was a primary motivation behind inventing the AMF format.
                                  An AMF exporter is still possible, but Cura's ignorance of AMF units makes it difficult to take Cura seriously.
                                  Moving on..
                                  Let's talk about expectations for the SketchUp model as they relate to AMF. AMF primarily expects solid volumes. These volumes map nicely to SketchUp solid Groups and solid ComponentInstances.
                                  Does it make sense to have the exporter only work on solid objects in SketchUp?
                                  Can you share a SketchUp model that you would expect to be exportable to AMF?
                                    BallBearing
                                    A solid two colors SketchUp file: SmallAndBigHeart-Solid.skp
                                    I check my stl files on Netfabb Or before that SU Solid Inspector. Sometimes NF says that my file is printable even when SketchUp Solid Inspector shows problems. NetFabb can export amf,but not import. And it's only a repairing models software.
                                    For 3D printing the model has to be solid. Usually I prefer to do:SU -> Netfabb -> SU or print.
                                    Slic3r also do not recognize inches. A bunch of other slicers do not accept amf, yet.
                                      Jim
                                      I think it makes more sense to organize the model using Groups or Components. So in the image the Heart is the amf <object> and the 2 sub-components are <volume> elements. AMF Volumes are solids, have a material, and can not over-lap.
                                      Material would be applied to each sub-component (volumes), but not the top-level Heart (object.)
                                      Using Groups/Components also has the advantage of instantly knowing if they are solid or not.
                                        Jim
                                        As a side note, Microsoft has included some support for printing to 3d printers[1]. There is a 3D Builder app[2] in the Microsoft store which loads .stl, .obj, and .3mf - Microsoft's version of .amf.
                                        I think I read Microsoft has licensed NetFabb technology for checking files.
                                        Maybe soon we will be 3d printing directly from SketchUp.
                                        [1] http://blogs.windows.com/bloggingwindows/2013/08/22/3d-printing-support-in-windows-8-1-explained/
                                        [2] http://apps.microsoft.com/windows/en-us/app/3d-builder/75f3f766-13b3-45e9-a62f-29590d5781f2
                                        3D Printing in Windows:
                                        http://msdn.microsoft.com/en-us/windows/hardware/bg183398
                                          Jim
                                          Test files round 2.
                                          The amf appears to load in the AMF Utilities, Cura, and Slic3r.
                                          su-exporter-test.amf.txt
                                            BallBearing
                                            Hi! Everyone do not like Microsoft's closed format:
                                            http://fabribles.com/forum/vox-pop/70-microsofts-3mf-file-format-no-thanks
                                            Slic3r & Cura can run on Windows, Mac OS X and Linux. They seems to have continuing updates & fast development which I cannot always say from MS products.
                                            Slic3r & Cura also have model fixing. I just think that a good model do not need holes filled with small triangles. Probably slowing the printing process? Or at least I try to do so clean model as possible usually.
                                            One part of the 1:3 skull: GrabCAD -> Meshlab -> SketchUp -> NetFabb -> Cura -> 3D Printer.
