    Animating Water Spray
    62 Posts 8 Posters 6.7k Views 8 Watching
    • ashscottA Offline
      ashscott
      Hi All,
      Am working on a project where I am animating a truck going through an automatic truck washing machine. As you can imagine there would be a lot of water flying around and showing this in any way is quite difficult. Some examples of our existing machinery: https://www.youtube.com/watch?v=WZFPDp4EESc
      I will be animating truck and machinery movements at the same time.
      I wondered about using a plugin like Animatex to animate a whole bunch of semi transparent PNG files but not sure how it would work out: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52238
      I have seen some discussion by Solo and Co over here that discusses inserting "movie screens" similar to what animatex does: http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=15651
      Has anyone had any experience with this? Im pretty confident when I say that this is not going to work on blender as there will be so much computation involved to render so much water...
      Suggestions?
      P.S. Why can I never remember how to embed youtube videos?
      Just some stuff I do with Sketchup.
        For the Youtube video πŸ˜„
        just use the balise
        http://sketchucation.com/forums/styles/abbcode/images/bbvideo.gif
        and erase the s of https !
        [bbvideo 640,480]https://sketchucation.com/click.php?url=http://www.youtube.com/watch?v=WZFPDp4EESc[/bbvideo]
        • ashscottA Offline
          ashscott
          Thanks Pilou,
          Got any suggestions for animating that kind of scene?
          • oceanembersO Offline
            oceanembers
            animated images on planes would be the way to go. Other than that, you could maybe do something with a blender particle system.
            • ashscottA Offline
              ashscott
              Seen any good tutorials/instructions for this?
                roland joseph
                It could be done in Lumion. Lumion is going to cost money but it is an investment your company can recover as it can be sold at anytime at it's retail value.
                (....and it took me all of 5 minutes to do this)
                I have just thrown around a bit of water spray so this is primative but with time you can emulate anything with the water effects. I tried the code supplied to embed but it is a mystery to me to so here is a link instead.....cheers!
                • ashscottA Offline
                  ashscott
                  Roland, that is the best attempt I have seen - really impressive.
                  Are you saying that you bought and then sold a Lumion license again? How did you sell it?
                  It does look impressive but I'm pretty scared of forking out 1500 euros if I'm not going to get it back again....
                  Roughly how long did it take to set up that animation?
                  NOTE: You embed into sketchucation using the "Insert Web Video" button but you need to change "https" to "http" in the youtube URL:
                    roland joseph
                    "Are you saying that you bought and then sold a Lumion license again? How did you sell it?"
                    I see licences on sale at the Lumion forum posted by members. I have not sold mine but when I didn't upgrade last time one of the support staff sent me a note saying I could sell if I wanted.. I will be moving to pro 5. At the moment I am still at version 3.2.1. I am a pretty small company so like you I am waiting till I have a fund built up to move ahead. I will be going to 5 as soon as I can. For sure the new year.
                    "It does look impressive but I'm pretty scared of forking out 1500 euros if I'm not going to get it back again...."
                    I like the Lumion guys (owners/developers) a lot and I try when I can to sell their product. Not for money but because I want them to prevail. I don't think you will want your money back if you are going to continue to visualize things....(but wait!)
                    "Roughly how long did it take to set up that animation?"
                    I did not fib..it took less than 5 minutes to do this so to get it looking real cool probably a couple of hours.
                    Tell you what. You complete the model and I will animate it for you. I don't think you should be under pressure to buy anything. Next time you can buy it and do it yourself.
                    I wouldn't volunteer for this unless it was easy.
                    Cheers!
                    p.s. thanks for the tip
                    • ashscottA Offline
                      ashscott
                      Wow, thats an amazing offer.
                      I'm still only part ways into the project so it will be a few more weeks before I animate it.
                      How is Lumion's object animation in your opinion? For example, in this animation I would need to show the truck moving forward, the brushes moving in on the side of the truck, wheels turning if possible.
                      Is Lumion capable of all this? I assume I export from SU to Lumion?
                      If the animation environment is outside of SU how do you handle the need to make tweaks to geometry and then re-animate?
                      You'll have to charge Lumion a commission if I end up buying!
                        roland joseph
                        " I would need to show the truck moving forward, the brushes moving in on the side of the truck, wheels turning if possible."
                        Yes all those things are easy to achieve. Like anything else we do I will go through a few iterations before I am satisfied. I would rate their object animation at a good solid 7 out of 10.
                        You just need to send me the skp and I can do the rest. There is an exporter for Lumion 5 to SU. 3.2.1 you simply export to file and then open so it is a manual process but just one extra click. If you see changes you want to make you just send me the edited file and I will reload. It is very easy to work many iterations.
                        These animations render in minutes not hours so again re-cooking is just a push of a button.
                        I am very busy at the moment so after Christmas if possible is best for me. If you need it before that I am still willing to get it done.
                        • ashscottA Offline
                          ashscott
                          Ok, let me tidy this thing up, set up an animation plan and I'll get back to you.
                          • panixiaP Offline
                            panixia
                            http://www.sidefx.com/index.php?option=com_content%26amp;task=blogcategory%26amp;id=103%26amp;Itemid=401
                            lol try this
                            i think lumion is way overpriced and i don't like the renders same photorealism as mikey mouse..
                              roland joseph
                              Just in case anyone was distracted by that last post. Here is a taste of one of those micky mouse animations with stock Lumion.
                              http://forum.lumion3d.com/gallery/enchanted-forest/
                              • panixiaP Offline
                                panixia
                                i see.."De gustibus non disputandum est" so if you love lumion that's fine.. BUT give a look at this.. and then anyone it's free to judge by himself the capabilityes of a 2000$application vs a 3000$ application so both intended to be professional grade packaging but i think if your work frequently belongs to water dinamics renders and so on the realism offered by software like houdini and similar packagings is so outstanding that in comparison lumion look like totally fake NPR renderings.. just my opinion.. if you like them just stuk with'em it's fine for me.. peace and love.. πŸ˜„
                                sorry for my poor english
                                  roland joseph
                                  I will not debate your point because there is some truth in it. Your English makes it come off a little harsh though.
                                  I do this because it gets me work. In fact so much that I am going to hire a modeller for the first time in my career. (my son..lol) Once upon a time I came across a product that stopped me in it's tracks. I turned it on and played with it all day like a big kid. About half way through that same day it came out of the blue like lightening (or I guess that would be black).....it struck me that I could make money with this thing. "This thing" was Sketchup. That day I got a feeling I have had only one other time since.
                                  That other time was my first day with Lumion.
                                  Lumion has it's limits for the consummate rendering artist. But so far it has no limits for me in terms of earning power. I am not a talented rendering artist. I am a hard working illustrator who loves his tools and has found a way to make money with them.
                                  Thank you Sketchup!
                                  Thank you Lumion!
                                  My life is much richer because you exist.
                                    roland joseph
                                    "I will not debate your point"
                                    What I forgot to mention is, I am willing to debate you but through my work. If you want to talk, you take a copy of the model when it is available after Christmas and we will have a go.
                                    I'll be proud to let the forum judge at that point where the value is.
                                    • panixiaP Offline
                                      panixia
                                      i 100% understand your point when you say sketchup is easy and productive and maybe fun to use and so maybe lumion.. i also understand that you want to have the faster and easier result and you don't want to learn a specific supermodeler/simulator software, also i have to say this is the very same exact reason why i actually don'use houdini and i use sketchup instead for my actual work..
                                      but some time ago i had some fun actually experimenting whit demo version of phoenix PD runningon my friend's 3dsmax.. actually this kid of software may appear intimidating from a sketchup user point of view whit so mmuch parameters and stuff.. but if you are not doing hollywood VFX in your everyday job (actually i think you won't neiter be paid to make enchanted forests in lumion πŸ˜› ) then handling some pretty basic simulations which can be useful let'say for you actual car-wash or fireplace or maybe some simple fountains and so on..
                                      i never get paid for some of this renders but the day i will do.. i will for sure consider try to learn some basic houdini (from what i can read here and there, "phoenix fd" which i tested is also a toy in comparison to houdini and it is not standalone you need 3dsmax or maya to run it) houdini can also model and render by itself and again my bad english don'help me to understand 100% but it seems to exist a cheap version of houdini you can use if you are not into film industry so i'think i will try this for fun as soon as possible..
                                      (www.sidefx.com)
                                      to demostrate the relative easiness of use of this kinds of fluid simulators thake a look at this jokes me and my friend did on a laptop having fun for an afternoon with phoenix.. and with a couple of click you can also pick collision objects like in the chocolate example below.. this can easily avoid the "mikey mouse effect" of the lumion water splashes wich penetrate into the car glasses in your example..
                                      let's consider we did this in an afternon because we were learning but the tutorial guy do this simulations in maybe 12mins and i would bet this could be set up in a couple of minute if you have a minimum of experience and you are actually on deadline and not doing tutorials and explaing every step.
                                      i apologize again for my bad english but maybe it's still better than your italian πŸ˜„
                                        roland joseph
                                        " If you want to talk, you take a copy of the model when it is available after Christmas and we will have a go."
                                        For this you have no answer so I guess the debate is over. I didn't think you would surrender so quickly.
                                        So at this point we are done talking.
                                        I'll be waiting here if you find your pants.
                                        • panixiaP Offline
                                          panixia
                                          i was suggesting to try something specific not "competing" or insulting so i'm very happy to "surrend" πŸ‘
                                          go on insultig and competing all alone. i'm too busy searching for my pants.. πŸ˜„
                                          so.. have a nice day.
                                            roland joseph
                                            @ashscott.... I wasn't kidding in case you thought I forgot.
                                            • 1 / 4
