    Always face center-line/ Magnetic tool
    56 Posts 9 Posters 5.7k Views 9 Watching
      driven
      @jolran said:
      ...The vectors are all setup, so I guess one could easily go for an angular approach instead...
      can't the vector be form child.bounding_box.centre to target.bounding_box.centre ?
      • jeff hammondJ
        @jolran said:
        EDIT: That Z_BRUSH model 😲 One of those belts of the model would kill Sketchup.
        ha, well, at least you could make a valiant effort of modeling that figure in sketchup.. you'll bump into polycount limitations but the geometry is still possible.. rhino could handle the geometry but it would be nearly impossible to do such fine detailing of organic surfaces like that with nurbs.
        zaha hadid's stuff could be considered 'organic' by many people but if you look at it differently, you'll usually see the pattern/logic/math emerge.. there are some hybrid sub-d/nurbs things happening nowadays but not much in core rhino in these regards.. maybe one day.
        it would be neat to see sketchup adopt some sort of psuedo-nurbs eventually ala bonzai3D (or now form•Z jr)
        • jolranJ
          jolran
          Jeff I hear what you're saying and understand what you are getting at. The complexity you wish would probably scare away many newbies, yes.
          It's difficult to find a balance of power and simplicity.
          I think XSI foundation did it nicely, but alas...
          But we can drop the subject if you prefer..
          they are already there, SU just fails to use them with it's own tools...
          but exports them to AutoCad, go figure...
          What do you mean. Does Sketchup have some underlying code I never heard about ? 😮
          I place the boxes on points from a grid. Those points can be reused for building the vectors to target. So it would probably be the same thing as you mean ?
          I suppose a "Align with vector" Node would be in order to transform locally in the vector direction.
          Anyway I try to keep a maximum of 50 nodes when developping, so I have to deal with this later. I just wanted to show that it could probably be done with point to target algorithm.
          However rereading the post more closely I don't think it's what the author wants. So back to Jeff and the magnetics 😄
          • jolranJ
            jolran
            Right! (about the model)
            Pseudo-Nurbs ?! I forgot about Forms. Should have a peek and see what the pseudo is about.
            It's problematic with the tesselation as Quad type in Sketchup since we can only use planar faces. Also adding geometry is fastest with Polygonmesh class which also requires triangles.
            So I don't know..
            In my case I'm only subdividing the tesselation/triangulation.
            But I agree, NURBS built into the Sketchup core would be nice.
            • jeff hammondJ
              i suppose you can get close enough if only pointing objects which are far away via 'always face CL/magnetic tool'..
              just deal with the inner ones a little differently
              • Flippie123F
                Flippie123
                @box said:
                On a side note, there is always Sketchy Physics for using Magnetism. But I can't imagine how that could be translated into fixed positions not to mention the time it takes to set things up. Perhaps the inner workings of SUPhy can lend something to another plugin.
                But it's a magnetic thread so I had to do something.
                waaaah! This looks very cool!
                • Flippie123F
                  Flippie123
                  Hi Jeff, I'm not trying to compete with Zaha. I have been using sketchup since the very beginning. In the beginning I started to do some simple architecture using sketchup but now years later I'm doing some pretty advanced architecture designs using sketchup where I'm trying to reach the limits of the program.
                  I'm very exited about sketchup2015 because the 64bit version makes much more possible.
                  Off course I can use Rhino to do some modelling. But at the end my clients want to see a Sketchup model because for them a sketchup model is easy to read.
                  @jeff hammond said:
                  @flippie123 said:
                  I did some experimenting with the pathcopy tool and some curved lines. I used 2 magnetic points here. But it will become really interesting if I can add 3,4 or 5 magnetic points.
                  I'm just a user...not a developer, but I can assure everyone that we are using sketchup to make the most awesome architecture here in our office.
                  don't you guys have a copy of rhino in your office?
                  i'm pretty sure zaha used paneling tools to create this.. possibly in conjunction with a custom script..
                  it's super powerful for various types of attractors etc..
                  [attachment=0:ddwi3rqq]<!-- ia0 -->Screen Shot 2014-12-10 at 10.59.16 AM.png<!-- ia0 -->[/attachment:ddwi3rqq]
                  heh.. neat ☀
                  • jeff hammondJ
                    my bad.. i suppose i read too literally when you posted her model saying 'i want to make this'
                    here are a couple example DC files showing attractor type stuff in sketchup.. maybe some ideas will spring from them:
                    created by sketchucation member TAEKLE
                    • jeff hammondJ
                      here's possibly the most basic dynamic component ever made 😄
                      DC_pointer.skp
                      it's a one liner:
                      just use the regular Move tool to move it around and make copies (though doesn't seem to work with copy/array)?.. it will always point at the origin.
                      (as is, you have to stay on the positive side of the red axis or it will point backwards)
                      • Flippie123F
                        Flippie123
                        haha...yes it always point to the center line but it is not magnetic. I tried to use the sketchyphysics tool but it only works for Sketchup7. And it is not easy to use. 🎉
                        • jeff hammondJ
                          hmm.. it was meant as proof of concept.. the origin in this case is "magnetic"..
                          copy a bunch of them around:
                          then select them all and move them at once:
                          with a less simple DC, you could make it the other way.. the objects stay put and you move the attractor around (though probably moving the the attractor via numerical input).
                          • BoxB
                            My model up there was done in 2015 32bit, the only version it doesn't work in at the moment is 2015 64bit. Make sure you are using the latest version.
                            Yes it can be difficult to use, it isn't the most easily understood plugin and the documentation is limited.
                            But mostly I don't think it would work for you as it doesn't really work for positioning stuff then placing it. It is more of an animation tool.
                            • cottyC
                              cotty
                              @flippie123 said:
                              ... but it only works for Sketchup7. And it is not easy to use. 🎉
                              That's wrong...
                              http://sketchucation.com/pluginstore?pln=SketchyPhysics
                              my SketchUp gallery
                              • jeff hammondJ
                                here's a dynamic component which does the thing in the original post..
                                DC_Magnet.skp
                                to use it:
                                • double-click the outer component (main) to enter it.. (there are two more components inside: box & attractor)
                                • Move the attractor component with the move tool
                                • exit the main component then right-click on it --> Dynamic Components-> Redraw.
                                  driven
                                  @jeff
                                  that's really good...
                                  • jeff hammondJ
                                    @driven said:
                                    @jeff
                                    thanks.
                                    a few more additions (right-click--> dynamic components -> component options)
                                    • pick the number of boxes (square array)
                                    • how many beers? (straightness of rows and columns waver)
                                    DC_Magnet_Beer.skp
                                    • jeff hammondJ
                                      1024 boxes, a 12-pack, and change the shape of the box component
                                      • Flippie123F
                                        Flippie123
                                        @Jeff
                                        I just made this and gave it a twist. Very awesome! 🎉 👍
                                        • jeff hammondJ
                                          yeah, it's something to do with replacing the box component with one on a different axis.. haven't quite figured out how to control it properly.. i made it this far:
                                          • jeff hammondJ
                                            sweet!
                                            (i'm not sure how to use the code but the gif looks cool 😉 👍 )
                                            • 2 / 3
