    Applying non broken texture to smooved sandbox mesh
    9 Posts 5 Posters 3.8k Views 5 Watching
      LARV
      I made a square of terrain using the sandbox and smoove tools. If I apply a texture to the mesh created, every little surface on the mesh will have a texture based only on that surface. I want to the material to follow, unbroken, the whole terrain object. How do I go about doing this?
      Did this post make any sense by the way?
      • cottyC Offline
        cotty
        The basic method:
        my SketchUp gallery
          LARV
          Great, thanks!
          • massimoM Offline
            massimo Moderator
            the basic method revisited:
            -enable hidden geometry: view-->tick hidden geometry;
            -apply the texture on a triangle;
            -right click on the triangle-->texture-->projected;
            -pick the paint bucket tool-->press alt and click on the texture in the triangle with the eyedropper;
            -disable hidden geometry: view-->untick hidden geometry;
            -paint the whole surface with the paint bucket.
              LARV
              Nice! That was perfect!
              • BoxB Offline
                BTW the Tick that shows the the thread has been answered normally goes on the post that is the answer, rather than the question. That way people can click on the tick and it will take them straight to the post that contains the answer.
                • massimoM Offline
                  massimo Moderator
                  Sorry, I think it was my fault. Should be ok now.
                  • BoxB Offline
                    No biggy, it was just that I had noticed it on a few threads lately and thought it worth pointing out.
                    • E Offline
                      edh635
                      To Massimo,
                      Thanks, it works perfectly all these years later. I took a while to find this approach. May I ask why it works, and/or how you discovered it?
                      Ed
