How To Print Sketches At A Higher Resolution?
Hello,
I'm curious if there is a way to make the sketches I need to print out into a higher resolution. I'm worried that if I make the paper size larger, it will distort the image and become unreadable. If I were rendering the image there would be no issue, however due to the fact that I am using Sketchup's built-in rendering engine, I have absolutely no idea whether or not that is feasible.
Don't print directly from SketchUp. Export a PNG file. Before clicking on 'Export', click on the Options button and set the desired size. Then print the PNG image as needed.
Thank you for the assistance! I think its been you answering all my questions over the course of this year. I greatly appreciate your time and effort.
