    [Plugin] Add Layer [1.1.0]
    58 Posts 23 Posters 15.7k Views 23 Watching
      jwhida
      I get the following error when I have multiple sketchup documents open (Document1, Document2).
      The error occurs when I try to use this tool in Document 2, and have previously created a new layer '-section-PLAN-L0' using this tool in Document 1.
      Error; #<ArgumentError; '-section-PLAN-L0' not valid values in list.>
      /Users/me/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jf_add_layer/SKUI/listbox.rb;207;in `value='
      /Users/me/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jf_add_layer/main.rb;37;in `main'
      /Users/me/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jf_add_layer/main.rb;205;in `block in <module;AddLayer>'
      SketchUp;1;in `call'
      Using SU-2015-15.3.329 on OSX Yosemite 10.10.2
        balaskes
        I really whish for an option in the dialogue box to choose layer visibility states in future creations of scenes to behave as they would normaly do, meaning copying exact layer visibility states from the scene used as the creation source. As it is now the dialogue offers you to choose eiter visible or invisible layer states in future scene creations. If this is implemented I will save a lot of time an be extremely greatfull!! Thanks!!!
        • greenskpG Offline
          greenskp
          When i rename a layer - 00_Equip --> 00_Equip.01 - and Add Layer[1.1.0] is open, if i closed and open it again, the ruby console show me the following error:
          Error; #<ArgumentError; '00_Equip' not valid values in list.>
          D;/Plugins/jf_add_layer/SKUI/listbox.rb;207;in `value='
          D;/plugins/jf_add_layer/main.rb;37;in `main'
          D;/Plugins/jf_add_layer/main.rb;205;in `block in <module;AddLayer>'
          • jujuJ Offline
            juju
            have you tried 00_Equip --> 00_Equip_01 ?
              Jim
              I updated the plugin to fix this error. The version is 1.1.1.
              Note however the dialog needs closed and reopened to recognize a renamed layer.
              • greenskpG Offline
                greenskp
                Thank you Jim. Working fine now.
                  ASistGar
                  Thanks so much!! Running perfectly
                    SK_Man_2020
                    I realize that this is an oldish plugin, but it's really useful, and seems to work great in v2017.
                    However, the layers in the pull-down list are shown in apparently random order... Is there any way of changing that, so they are in alphabetical order, just like in the actual SK "Layers" window?
                    I often have many dozens (or even hundreds) of layers in my models, so it's a real pain to scroll through a long list, looking for the ones I want. It would be great to have the option to sort that list in alphabetical order, and even better if it could be set to either ascending or descending order.
                      glro
                      when i click on 'name' (title of the column) in the window that shows layers, they are put in alphabetical order...
                        SK_Man_2020
                        Then I guess I must have an older version of the plugin, because I don't see any "name" column in the plugin. All I see is a pull-down box with an arrow pointing down, and a button next to it labeled "New". Below that is a check box labeled "Layer visible on selected Scene only". If I click in that pull-down, I get the list of layers, but they are in random order. I don't see any column labeled "Name" on the plugin window. That's only in the layers window, not the plugin window. And when I click on "name" in the layers window, it does not change the order of the layers in the plugin window, only in the layers window.
                        What version of the plugin are you using? Is there a new version that has a "name" column on it?
                        This is what I get: Are you seeing something different?
                          glro
                          [attachment=2:2q4kk0ic]<!-- ia2 -->AddLayer-window.jpg<!-- ia2 -->[/attachment:2q4kk0ic]
                          i misunderstood your question; but i modified the plugin the way you want it
                          i just added one line:
                          layers.sort!
                          to the file 'main.rb'
                          (joined)
                          you just have to put it in your plugin folder, instead of the one that is already there
                          and the layers will be shown by alphabetic order
                          by alphabetic order
                          main.rb
                            SK_Man_2020
                            Wow! Cool! Thank you so much! That's VERY useful. Makes things a whole lot easier when there's hundreds of layers in a file. I wish I had the time to learn Ruby so I could do that type of thing.
                            Thanks again! Very much appreciated.
                              glro
                              you are welcome
                              this is what the forum is for
                                blackdogsketch
                                Jim
                                Cannot find this any longer. Not in the Extension Store and the manual download link on your blog doesn't work for me.
                                This is a super valuable tool for me and switching over to 2018 I've lost it.
                                Any help would be appreciated. Thanks.
                                  sloworg
                                  Hi all, I too have been on the search for Jim's Add_Layer plugin to no avail. Does anyone have a link or a copy that will work with Make 2017, please?
                                  Thanks in advance
                                  • 3 / 3
