    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 57.8k Views 69 Watching
      @jql said:
      (Thomthom - I submited the bugsplats.)
      Which platform and what OS? Did you mention Bezier Surface in the BugSplats?
        @jql said:
        I think subdivision is really important to be able to input quickly, but distance is even more. What would you feel about introducing subdivisions as "2s" while "2" would be used for units?
        That sounds like a good idea. Filing feature request.
          @box said:
          Yes for me using the Gizmo defaults to subdivisions and will bug splat if you try 2.
          I'm not entirely sure I understand the steps for this. Can you elaborate?
          • BoxB Offline
            If you type 2 enter, in other words try to set the subdivisions to 2, it will bug splatt.
            • OxerO Offline
              Oxer
              Other suggestion, it would be very interesting if you could adjust the control points to a external geometry of the bezier surface, like the inference in SU, so you can adjust quickly your bezier surface to a predefined shape.
              • KrisidiousK Offline
                Krisidious
                Where are the instructions?
                By: Kristoff Rand
                • OxerO Offline
                  Oxer
                  Rich posted a video explanation here:
                  @rich o brien said:
                  You're gonna love this.....
                    Krisidious
                    Thanks Oxer.
                    By: Kristoff Rand
                      I have reproduced this and created a fix. The fix will appear in TT_Lib2 however. I'm still looking into a couple of other issues - so I'm not pushing an update right now. Just be careful no to change the subdivs to less than 3 until Bezier Surface and TT_Lib2 is updated.
                        @box said:
                        I found a little problem with it.
                        If you scale to 0 as a way of straightening an edge it freezes and won't update the surface. If you get out of edit mode and go back in an move a point it will revert to the unscaled skin.
                        http://i155.photobucket.com/albums/s296/storeben/SU/0Scale.gif
                        This is turning out to be trickier to fix. What happens is that when you scale the edges it currently scales the handles. So when you scale to zero it scales the handles to zero and all kind of bad things happen.
                        I need to add the implicit handle scaling as an option (by default off is probably best). Also need to prevent handles from becoming completely zero length - or some way to restore them.
                        There is also an issue in the current way the scaling that once you have scaled to zero, nothing will scale back. That is even tricker to fix.
                        I need to split this out into multiple fixes.
                        You can check the status in the Issue Tracker:
                        https://bitbucket.org/thomthom/bezier-surface/issues?status=new%26amp;status=open
                        • BoxB Offline
                          Thanks for looking into it Thomthom, it's such a good tool, with amazing potential.
                          I tried Bezier Triangle today from EH and it's nowhere near as good.
                          • JQLJ Offline
                            JQL
                            Win7 SU2015 64bits and I believe I did mention Bezier Surface
                            www.casca.pt
                            Visit us on facebook!
                            • JQLJ Offline
                              JQL
                              Would be perfect.
                              And what if you'd pick a quadface (defined in quadface tools) and convert it on a bezier patch.
                              www.casca.pt
                                I've uploaded a new version of TT_Lib2 which should fix the crash. You can now safely set the segments down to 1 if you like.
                                  AcesHigh
                                  I am getting this error message in SKP 2015
                                  I wonder if "Error: #<Encoding::CompatibilityError: incompatible character encodings: ASCII-8BIT and UTF-8>" refers to the fact the default new plugins folder path is the "USER" and in my language it´s USUÁRIO with that accent over the A.
                                  Error Loading File C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/core.rb
                                  C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:109:in end_with?' C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:109:in rescue in require'
                                  C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:35:in require' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/core.rb:117:in block in module:BezierSurfaceTools'
                                  C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/core.rb:115:in each' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/core.rb:115:in module:BezierSurfaceTools'
                                  C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface/core.rb:33:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
                                  C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface.rb:42:in register_extension'
                                  C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface.rb:42:in <module:BezierSurfaceTools>' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface.rb:15:in module:Plugins'
                                  C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface.rb:14:in <module:TT>' C:/Users/Usuário/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/tt_bezier_surface.rb:13:in <top (required)>'
                                    Yes ... but I thought I had fixed that. Exactly what version do you have installed?
                                      Meh! I can reproduce this. Another Ruby encoding issue with filesystem functions. I think I have a fix for this. Look for an update.
                                        Just realized I'd forgotten to push a couple of other fixes so I uploaded a new version now (0.1.3). Live on PluginStore - pending review on Extension Warehouse.
                                        • JQLJ Offline
                                          JQL
                                          Aren't you the one reviewing extensions on EW? That seems beurocratic... 😎
                                          BTW what a great tool you have here... full of possibilities!
                                          Would rival the rotated rectangle tool/pushpull combo if my buildings weren't so... well... flat!
                                          Thanks again Thomthom!
                                          www.casca.pt
                                            I'm not the sole person handling it. And it wouldn't be right for me to review my own extension. 😉
                                            • 12
                                            • 13
                                            • 4 / 13
