    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 57.9k Views 69 Watching
    • KrisidiousK Offline
      Krisidious
      looking good.
      By: Kristoff Rand
      • cottyC Offline
        cotty
        @thomthom said:
        I'm about to take a weeks vacation so I'll be off the grid.
        I wish you a pleasant and relaxing holiday!
        my SketchUp gallery
          What a tub! โ˜€
            Anton_S
            But, will it blend?
            • tt_suT Offline
              tt_su
              @pbacot said:
              I could do that in say, 20 min. I can just send it to Box and open the file when it comes back done ๐Ÿ˜„
              Got a patch view of that?
              • BoxB Offline
                I assume you are asking me.
                No I don't have the original as you need to explode it to work on it.
                It would have looked very similar to this before I trimmed the rim and gave it a follow me profile. It's only a few moves to create it, move the center down, scale a few points lift a bit here and there.....
                  pomelo3d
                  thank you very much for sharing this very fun tool.
                  a consultation:
                  as add tripatch tool is used?
                    @jql said:
                    (Thomthom - I submited the bugsplats.)
                    Which platform and what OS? Did you mention Bezier Surface in the BugSplats?
                      @jql said:
                      I think subdivision is really important to be able to input quickly, but distance is even more. What would you feel about introducing subdivisions as "2s" while "2" would be used for units?
                      That sounds like a good idea. Filing feature request.
                        @box said:
                        Yes for me using the Gizmo defaults to subdivisions and will bug splat if you try 2.
                        I'm not entirely sure I understand the steps for this. Can you elaborate?
                        • BoxB Offline
                          If you type 2 enter, in other words try to set the subdivisions to 2, it will bug splatt.
                          • OxerO Offline
                            Oxer
                            Other suggestion, it would be very interesting if you could adjust the control points to a external geometry of the bezier surface, like the inference in SU, so you can adjust quickly your bezier surface to a predefined shape.
                              Krisidious
                              Where are the instructions?
                              By: Kristoff Rand
                              • OxerO Offline
                                Oxer
                                Rich posted a video explanation here:
                                @rich o brien said:
                                You're gonna love this.....
                                  Krisidious
                                  Thanks Oxer.
                                  By: Kristoff Rand
                                    I have reproduced this and created a fix. The fix will appear in TT_Lib2 however. I'm still looking into a couple of other issues - so I'm not pushing an update right now. Just be careful no to change the subdivs to less than 3 until Bezier Surface and TT_Lib2 is updated.
                                      @box said:
                                      I found a little problem with it.
                                      If you scale to 0 as a way of straightening an edge it freezes and won't update the surface. If you get out of edit mode and go back in an move a point it will revert to the unscaled skin.
                                      http://i155.photobucket.com/albums/s296/storeben/SU/0Scale.gif
                                      This is turning out to be trickier to fix. What happens is that when you scale the edges it currently scales the handles. So when you scale to zero it scales the handles to zero and all kind of bad things happen.
                                      I need to add the implicit handle scaling as an option (by default off is probably best). Also need to prevent handles from becoming completely zero length - or some way to restore them.
                                      There is also an issue in the current way the scaling that once you have scaled to zero, nothing will scale back. That is even tricker to fix.
                                      I need to split this out into multiple fixes.
                                      You can check the status in the Issue Tracker:
                                      https://bitbucket.org/thomthom/bezier-surface/issues?status=new%26amp;status=open
                                      • BoxB Offline
                                        Thanks for looking into it Thomthom, it's such a good tool, with amazing potential.
                                        I tried Bezier Triangle today from EH and it's nowhere near as good.
                                        • JQLJ Offline
                                          JQL
                                          Win7 SU2015 64bits and I believe I did mention Bezier Surface
                                          www.casca.pt
                                          Visit us on facebook!
                                          • JQLJ Offline
                                            JQL
                                            Would be perfect.
                                            And what if you'd pick a quadface (defined in quadface tools) and convert it on a bezier patch.
                                            www.casca.pt
                                            • 12
                                            • 13
                                            • 3 / 13
