    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 402.2k Views 80 Watching
    • CadFatherC Offline
      CadFather
      yeeeeaaa! fantastic Master Anton, works ghurait now! πŸ˜„ πŸ‘
        dtrarch
        ams window dialog stuck.jpgHi Anton
        The settings dialog icon from your plugin tries to open the SU program dialog for an instant but closes and just opens your settings.
        No way to move to another monitor or make floating.
        just a fixed location per my screen clip.
        (Your settings is grayed out by screen capture software)
        Win 7 pro
        SU 2015 pro
        Firfox
        This is a must have script and thanks thanks thanks.
        A fix would sure be appreciated
        Dave
          Anton_S
          I removed the pick and drag feature, just cause I thought upper-right corner of the view was the best location for the dialog. I might re-add it in the next release.
          It looks like my plugin tries create a new dialog, but in fact, that's the same dialog with border and caption removed. I will make it do such procedure faster, so it's done before the dialog is set visible.
            dtrarch
            Anton
            The pick-and-drag gang will beg
            dtr
              dtrarch
              Hi Anton
              The border and caption (SU)will be needed to drag the plugin.
              Also to locate the plugin on another screen.
              Dave
                Anton_S
                @dtrarch said:
                Hi Anton
                Dave
                I won't add the border and caption, cause I think the widows frame doesn't look so good, but I will make the green heading draggable and clippable...
                  dtrarch
                  Hi Anton
                  Good news to be able to drag.
                  Will it lock to other SU captions ?
                  Very handy to set a typ screen org for templates.
                  Here is how I use them in any case.
                  (in line here)
                  SU Window Settings is on screen #2
                  Your plugin should have been part of SU from the very beginning.
                  Thanks for getting back too.
                  Dave
                    Anton_S
                    4.1.0 has been released!
                    • Added pick, drag and clip feature to the new dialog.
                    • Made borders hide faster.
                    • Added localization to dialog.
                    Click on green caption to drag the dialog, easy as that...
                      dtrarch
                      Anton
                      V4.1.0 did not drag (or move) green title and would not close menu when arrow was clicked.
                      SU title hide was still slow.
                      Show/Hide toolbars and dialogs killed all my on screen settings for both when invoked.
                      Sorry
                      Dave
                        Anton_S
                        @dtrarch said:
                        Anton
                        Sorry
                        Dave
                        It works well on my windows 7. What operating system are you using and what internet explorer version?
                        Edit: I tested on my Windows XP (with IE9) and it doesn't work just like you described. There is not much I can do about compatibility other than retrieving the original version. So, if you use IE9, use the old version which is compatible in SU2014 and below. You need AMS Library 1.0.9 for the old version too. Here are the links:
                        ams_lib_1.0.9.zip
                        ams_WindowSetttings_3.8.1.zip
                          dtrarch
                          Hi Anton
                          I have Win 7 pro
                          SU 2015 pro
                          (this is the problem SU version)
                          (Not much else installed)
                          Tig extrude lines.rb
                          Wiki tools
                          Works fine on SU 2014 Pro
                          Firefox browser most updated
                          Win Explorer 11 installed
                          Dave
                            Anton_S
                            Ok, I will look into it
                              Anton_S
                              By your screenshots I noticed you're using windows classic theme. If that so, try settings it to aero theme in see how it goes.
                                dtrarch
                                Hi Anton
                                I tried Aero and no change. 😒 😒
                                Dave
                                  Anton_S
                                  In prior post you mentioned that works fine in SU2014, but not in SU2015. If that so, are you speaking of version 4.1.0? I.E do you have 4.1.0 installed on both SU versions? With regards to that, do you have AMS Library 2.0.0 installed in SU2014 and SU2015?
                                    dtrarch
                                    Anton
                                    Here are my setups for your plugin.
                                    SU 2014 Pro (works properly)
                                    Lib 1.0.8
                                    Win 3.8.0
                                    SU 2015 Pro 64
                                    Lib 2.0.0
                                    Win 4.1.0
                                    Perhaps the problem is in not having the SU title stay with your menu(s)then attached.
                                    In SU 2014 I select the SU title to drag and your menus stick to it and go along with it when dragged.
                                    Also my SU 2015 is 64 bit version.
                                    Hope that helps
                                    Dave
                                      Anton_S
                                      Version 4.1.5 Had been released!
                                      • Fixed pick and drag bug.
                                      • Adjusted close button size.
                                      • Disabled high contrast optimization.
                                      • Made compatible with IE9.
                                      Thanks do dtrarch for reporting the bug.
                                        dtrarch
                                        Noel Anton
                                        FYI
                                        Last update works properly but when moved to second screen and saved as template/file your title/pull down menu location is not remembered.
                                        It shows up on primary screen as SU title and then changes to your title when moved.
                                        I know you do not like the way the SU tiles look but I think this SU title must stick/remain when moved so that the saved file can remember the location as a SU function.
                                        Thanks again so much for all your good work and this super Plugin. πŸ‘ πŸ‘ πŸ‘
                                        Cheers
                                        Dave
                                          Anton_S
                                          MMMOkay, I will look into this. πŸ˜‰
                                            dtrarch
                                            Hi Anton
                                            Any chance to look at the Menu/remember location question.??? πŸ’­
                                            In any case.
                                            Happy New Year in the Wetlands of Ore.
                                            Dave
                                            • 14
                                            • 15
                                            • 3 / 15
