    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 57.9k Views 69 Watching
      @pilou said:
      Components on face by CPlassais
      That is using the exact code that smartdrop.rb uses - which is bugged and breaks the Ruby API.
      class Sketchup;;Group
              def definition
                      return(entities[0].parent)
      I'm about to take a weeks vacation so I'll be off the grid. Pilou, since you worked with him, care to follow up with him on the issue? Request that he updates his extension to not modify the Ruby API?
        No problem I will send him this advice! 😄
        • JQLJ Offline
          JQL
          Hi Thomthom and guys, can anyone move a point with a fixed measurement?
          Each time I try to move say 2m to the side, the measurement box assumes I want 2 subdivisions and the SU bugsplats. Is it only me and maybe a plugin clash or does it happen to more users?
          I think subdivision is really important to be able to input quickly, but distance is even more. What would you feel about introducing subdivisions as "2s" while "2" would be used for units?
          (Thomthom - I submited the bugsplats.)
          What a wonderful plugin this is! Such an intuitive way of modeling surfaces!
          Thanks,
          João
          www.casca.pt
          Visit us on facebook!
          • BoxB Offline
            Yes for me using the Gizmo defaults to subdivisions and will bug splat if you try 2.
            However, the Move tool works properly with measurements, including 2m.
            • BoxB Offline
              I think this will become the skinning plugin of choice for bodywork and such very quickly.
              For example: You know how fiddly it can be to set up the sections to make a nice curviloft helicopter, or a smooth hood for you car etc etc
              This Huey skin took no time at all, it's all done by eye, a little more effort or a framework to work to and you would have lovely clean skins.
              • pep75P Offline
                pep75
                Another brilliant plugin ThomThom!!! Great!!!
                • BoxB Offline
                  Another situation where surface is brilliant.
                  The ten minute custom shaped bathtub.
                  The bath itself and it's edge are a solid skin, theoretically printable.
                  http://i155.photobucket.com/albums/s296/storeben/SU/Bath.png
                  • JQLJ Offline
                    JQL
                    Yes I noticed that move works...
                    Shame also that we can't scale to 0.
                    Those are the only things that make this imperfect, otherwise the tool is GORGEOUS to work with!
                    www.casca.pt
                    • pbacotP Offline
                      I could do that in say, 20 min. I can just send it to Box and open the file when it comes back done 😄
                      • KrisidiousK Offline
                        Krisidious
                        looking good.
                        By: Kristoff Rand
                        • cottyC Offline
                          cotty
                          I wish you a pleasant and relaxing holiday!
                          my SketchUp gallery
                            What a tub! ☀
                              Anton_S
                              But, will it blend?
                              • tt_suT Offline
                                tt_su
                                Got a patch view of that?
                                • BoxB Offline
                                  I assume you are asking me.
                                  No I don't have the original as you need to explode it to work on it.
                                  It would have looked very similar to this before I trimmed the rim and gave it a follow me profile. It's only a few moves to create it, move the center down, scale a few points lift a bit here and there.....
                                    pomelo3d
                                    thank you very much for sharing this very fun tool.
                                    a consultation:
                                    as add tripatch tool is used?
                                      Which platform and what OS? Did you mention Bezier Surface in the BugSplats?
                                        That sounds like a good idea. Filing feature request.
                                          I'm not entirely sure I understand the steps for this. Can you elaborate?
                                          • BoxB Offline
                                            If you type 2 enter, in other words try to set the subdivisions to 2, it will bug splatt.
                                            • 12
                                            • 13
                                            • 3 / 13
