    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 77.6k Views 69 Watching
      @jeff hammond said:
      tangent blends aren't the smoothest since they abruptly change from one direction to another and you will see a more defined line in light/reflections.. you want something that eases into the transition.. bezier surface provides this type of blend (a little more control/ snapping of control points is necessary but as is, it still gets the job done.)
      Got a wireframe of that mesh? I'm curious to what makes out the difference. (I'm wondering if my SUbD tool might address that.)
        But the one that cause problems, that not publicly available? I was hoping to be able to inspect it and then see if I could reach out to the author and ask that he can release a new version that doesn't conflict.
        Components on face by CPlassais
        • jeff hammondJ Offline
          the render mesh looks like this:
          the tangent one has all facets at equal angles/sizes whereas the g3 blend starts off mellower then gradually tightens..
          at the highest end, this stuff only really matters if you're designing surfaces for cars etc but at the midTOlow end, some of it can & should trickle down into sketchup/architecture/furniture/etc.
            That is using the exact code that smartdrop.rb uses - which is bugged and breaks the Ruby API.
            class Sketchup;;Group
                    def definition
                            return(entities[0].parent)
            I'm about to take a weeks vacation so I'll be off the grid. Pilou, since you worked with him, care to follow up with him on the issue? Request that he updates his extension to not modify the Ruby API?
              No problem I will send him this advice! 😄
              • JQLJ Offline
                JQL
                Hi Thomthom and guys, can anyone move a point with a fixed measurement?
                Each time I try to move say 2m to the side, the measurement box assumes I want 2 subdivisions and the SU bugsplats. Is it only me and maybe a plugin clash or does it happen to more users?
                I think subdivision is really important to be able to input quickly, but distance is even more. What would you feel about introducing subdivisions as "2s" while "2" would be used for units?
                (Thomthom - I submited the bugsplats.)
                What a wonderful plugin this is! Such an intuitive way of modeling surfaces!
                Thanks,
                João
                www.casca.pt
                Visit us on facebook!
                • BoxB Offline
                  Yes for me using the Gizmo defaults to subdivisions and will bug splat if you try 2.
                  However, the Move tool works properly with measurements, including 2m.
                  • BoxB Offline
                    I think this will become the skinning plugin of choice for bodywork and such very quickly.
                    For example: You know how fiddly it can be to set up the sections to make a nice curviloft helicopter, or a smooth hood for you car etc etc
                    This Huey skin took no time at all, it's all done by eye, a little more effort or a framework to work to and you would have lovely clean skins.
                    • pep75P Offline
                      pep75
                      Another brilliant plugin ThomThom!!! Great!!!
                      • BoxB Offline
                        Another situation where surface is brilliant.
                        The ten minute custom shaped bathtub.
                        The bath itself and it's edge are a solid skin, theoretically printable.
                        http://i155.photobucket.com/albums/s296/storeben/SU/Bath.png
                        • JQLJ Offline
                          JQL
                          Yes I noticed that move works...
                          Shame also that we can't scale to 0.
                          Those are the only things that make this imperfect, otherwise the tool is GORGEOUS to work with!
                          www.casca.pt
                          • pbacotP Offline
                            I could do that in say, 20 min. I can just send it to Box and open the file when it comes back done 😄
                            • KrisidiousK Offline
                              Krisidious
                              looking good.
                              By: Kristoff Rand
                              • cottyC Offline
                                cotty
                                I wish you a pleasant and relaxing holiday!
                                my SketchUp gallery
                                  What a tub! ☀
                                    Anton_S
                                    But, will it blend?
                                    • tt_suT Offline
                                      tt_su
                                      Got a patch view of that?
                                      • BoxB Offline
                                        I assume you are asking me.
                                        No I don't have the original as you need to explode it to work on it.
                                        It would have looked very similar to this before I trimmed the rim and gave it a follow me profile. It's only a few moves to create it, move the center down, scale a few points lift a bit here and there.....
                                          pomelo3d
                                          thank you very much for sharing this very fun tool.
                                          a consultation:
                                          as add tripatch tool is used?
                                            Which platform and what OS? Did you mention Bezier Surface in the BugSplats?
                                            • 11
                                            • 12
                                            • 13
                                            • 11 / 13
