OS X Thumbnails for SketchUp files
yeah, the thumbnails are already in there (though 128px maximum)
graphic converter can read them and display them in its browser.. here's an example of me browsing a folder containing skps with graphic converter..
you can also have graphic converter switch all the icons for you so when you view them via finder, you'll see the thumbnails instead of the generic icon or the custom SU icon thing with the pin..
Thank you, Mr. Hammond!
I have huge respect for someone who responds with such detail to forum questions.Now, wouldn't it be great if OSX could access these thumbnails to begin with. Aren't there quick-view plugins for all sorts of file formats? If there is a way to render Autocad previews in finder, there must be a relatively simple pipeline to display a thumbnail that's already in the file.
I suppose, this doesn't affect all too many people.
Thanks for the workaround!Regards,
SAM from Vienna. -
Thanks so much for your advice. Graphic Converter worked.
I sure do wish Finder would just display the thumbnail properly.
Go Steelers!
Joe -
Hi Jeff,
I have followed your advice regarding using Graphic Converter but my SU files still show the SU icon rather than a file preview. Has something changed in SU that prohibits GC from changing the icon image.
Hope you can shed some light.
Cheers....Scotty
Version seems to be different. 7 performs as described but not 9
How do you do this? It is not clear from GC User Guide.
Cheers....Stuart
I'm not sure GC still works with skps, it stopped for a while at least, so I wrote a plugin...
I'll PM you this 'beta' plugin that lets you add icons to your skps that Finder/QuickLook can see, if you want?
I use it to add an icon from the 'File Menu' or a tool button any time I want, i.e. not auto on close.
It does do batches as well, but I need to do a little more on that before I release it to public...
I've had no horror stories from the dozen or more users who are 'testing' it.
john -
John,
I'd be very grateful to get a copy of your OSX thumbnail/icon plugin.
Thanks,
Chris -
In OSX 10.10., having preview turned on in Finder is a nightmare if one clicks on an SKP file. After much beachball spinning a preview consisting of the Chinese alphabet repeated endlessly (or something like it) appears. For large files, I have to force quit the finder to stop the useless waiting.
Until now, I have kept Sketchup files in folders that relate to whatever project I am working on but it's too easy to accidentally click on a file this way. I am now consider moving all SP files to a separate location.
try reseting QuickLook from Terminal.appqlmanage -r && killall FinderI'll PM my plugin...
john -
John,
Many thanks for your help here and in PMs. Problem now solved by deleting a Qlgenerator that I installed recently and which I had clean forgotten all about - duh!Chris
@chris,
the posts from here have a massive delay, today...
glad you found the culprit,
batch_icons is in the help menu...
it's a little verbose and the instructions are on the first dialog you'll see...
do a small folder and post the results, maybe I should release it???
john -
John,
I have now tried batching with SKP, SKM and Layout files. They all seem to work OK - very well in fact with the exception of a single glitch with one layout file that retained the image from another file. I need to examine the file tomorrow to see if it is indeed a glitch with the plugin or more likely, something on my partā¦I'd say the plugin is definitely release worthy!
@chrisjk said:
...a single glitch with one layout file that retained the image from another file. I need to examine the file tomorrow ...
.skm and .layout just grab the referenced image in the file [it just a zipped folder], so have a look at why it has the wrong referenced image...
glad you like it
john -
[attachment=0:a5t9bzkz]<!-- ia0 -->2014-11-04 07.55.41 pm.png<!-- ia0 -->[/attachment:a5t9bzkz]
johnHello John, I too would be very grateful to get a copy of your OSX thumbnail/icon plugin please.
Luds -
This post is deleted!
With your input, this post could be even better š
