    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 294.4k Views 172 Watching
      Try this version of the same file.
      I've changed the load order of the added code so it might be there before the 'tool' js raises the error...
      Report back ๐Ÿ˜’
      main.zip
        driven
        nope...
        [Error] TypeError; undefined is not an object (evaluating 'a.browser.msie')
        	(anonymous function) (jquery.tools.min.js, line 14)
        	global code (jquery.tools.min.js, line 14)
          Bother !
          I'll swot up on alternatives...
          ๐Ÿ˜’
            Please try this version...
            Different js fixing code yet again...
            main.zip
              driven
              Success, that got rid of the js [msie] error...
              obviously, I still get the missing icon errors...
              they are also called from jquery-ui.min.css as default images, but the folder is missing...
                Thanks for your help.
                I compile an update.
                I'll also look at this image failure...
                  driven
                  one example is on line 7
                  .ui-state-default{border;1px solid #ccc;background;#f6f6f6 url("images/ui-bg_glass_100_f6f6f6_1x400.png")
                  maybe just add the images, they must have been culled at some point...
                    Here's an update 0.6.6xx http://sketchucation.com/pluginstore?pln=SketchupIvy
                    The jquery/js in the html is adjusted to prevent some load-errors, which were reported on some MAC.
                    Some missing [but unused] image files are also now included to avoid some odd jquery/ui/css errors...
                    • ChisainaC Offline
                      Chisaina
                      It's a fine joke about version 0.6.6?
                      The archive is version 0.6.5. And she does not work correctly in the SU2014.
                      As bugs and leaves and with the lash. Very sensitive to changes in the settings. Please correct. Thanks in advance
                        You are mistaken.
                        It is 0.6.6xx - where did you get v0.6.5 ?
                        The LiveIvy::VERSION did report incorrectly, but it's now reset at 0.6..., so the sub-version updates shouldn't show in the dialog-header?
                        The dialog should show 0.6... - no more ?
                        In case you have mistakenly downloaded some older versions I have removed these from the initial posts.
                        Have you uninstalled any earlier LiveIvy.rb and the matching subfile with that name ?
                        You then need to reinstalled the full set from the downloaded PluginStore's RBZ, or AutoInstall it from the PluginStore dialog within SketchUp...
                        It works fine in v2014 and v2015 [AND v8 and v2013 !]
                        I do NOT understand your 'bugs/leaves/lash' comments.
                        It IS sensitive to changes in the settings, BUT it always was like that...
                        All I have done is make it compatible with newest versions of SketchUp, plus I added support for alternative ivyleaf_ SKPs etc...
                        EDIT: v0.6.7x is now available see a few posts after this...
                          driven
                          image folder needs to be inside the css folder, then I have no errors at all...
                            Dam' - I suspected as much !
                            50:50 - jumped the wrong way.
                            I'll fix it and release an update...
                              Here's v0.6.7x [please note how it shows in the dialog header as '0.6...' - ALL "v0.6..." files should do this...]
                              It hopefully now fixes the final issue on some MACs, with the 'images' folder needed in the jquery/ui/js etc in the css folder [it does a 'tidyup' and removes any incorrectly located images subfolder automatically when it first loads]...
                              • KrisidiousK Offline
                                Krisidious
                                Thanks a lot for squaring this thing up Tig. It's nice to have it back in the stable.
                                By: Kristoff Rand
                                • cheddaC Offline
                                  chedda
                                  Yes thanks for your work on this. I can launch the dialog window in new simple files. But for some reason i cannot launch this in existing model files. skp 2014 mac osx 10.9.5 Perhaps it is conflicting with the maxwell plugin ?
                                  Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                    maxosmedia
                                    Does not work properly with SU 2015 (Mac OS X 10.9.5) โ€” makes only one branch, no leaves. With SU 2014 everything is ok
                                    • OxerO Offline
                                      Oxer
                                      For me it works fine on SU2014/15 & OSX 10.9.5, remember the keys on Mac:
                                      Start grow ivy -->Click
                                      To make grow ivy to the mouse position-->CMD +Click
                                      Make leafs -->ALT+Click
                                      Finish the ivy --> SHIFT+Click
                                      Reset the ivy--> i key
                                        maxosmedia
                                        • cheddaC Offline
                                          chedda
                                          For me it grows and works fine in new files. If i try and open a previous project file i can't get the dialog window to open. It seems to stall.
                                            MalyJacek
                                            I see response to my request to add the ability to choose the leaves.
                                            In the summer I started doing sets of components for the various plants.
                                            They are in varying degrees of completion. https://dl.dropboxusercontent.com/u/32445396/ivyleaf_pasthenocissus.zip
                                            Here is a package for "wild vine" (Parthenocissus) is not 100% like I wanted but one of the curiosities that I wanted to enter. Namely, they are leaves added on two layers of autumn (jesieล„) and summer (lato) allowing you to quickly change the color by switching layer.
                                            In the future, if you have enough creative inspiration and I will try to finish the remaining sets I am working on and share them.
                                            Sorry for the grammatical errors have not practiced my English for a long long time
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 37 / 37
