    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 450.2k Views 172 Watching
      Thanks for your help.
      I compile an update.
      I'll also look at this image failure...
        driven
        one example is on line 7
        .ui-state-default{border;1px solid #ccc;background;#f6f6f6 url("images/ui-bg_glass_100_f6f6f6_1x400.png")
        maybe just add the images, they must have been culled at some point...
          Here's an update 0.6.6xx http://sketchucation.com/pluginstore?pln=SketchupIvy
          The jquery/js in the html is adjusted to prevent some load-errors, which were reported on some MAC.
          Some missing [but unused] image files are also now included to avoid some odd jquery/ui/css errors...
          • ChisainaC Offline
            Chisaina
            It's a fine joke about version 0.6.6?
            The archive is version 0.6.5. And she does not work correctly in the SU2014.
            As bugs and leaves and with the lash. Very sensitive to changes in the settings. Please correct. Thanks in advance
              You are mistaken.
              It is 0.6.6xx - where did you get v0.6.5 ?
              The LiveIvy::VERSION did report incorrectly, but it's now reset at 0.6..., so the sub-version updates shouldn't show in the dialog-header?
              The dialog should show 0.6... - no more ?
              In case you have mistakenly downloaded some older versions I have removed these from the initial posts.
              Have you uninstalled any earlier LiveIvy.rb and the matching subfile with that name ?
              You then need to reinstalled the full set from the downloaded PluginStore's RBZ, or AutoInstall it from the PluginStore dialog within SketchUp...
              It works fine in v2014 and v2015 [AND v8 and v2013 !]
              I do NOT understand your 'bugs/leaves/lash' comments.
              It IS sensitive to changes in the settings, BUT it always was like that...
              All I have done is make it compatible with newest versions of SketchUp, plus I added support for alternative ivyleaf_ SKPs etc...
              EDIT: v0.6.7x is now available see a few posts after this...
                driven
                image folder needs to be inside the css folder, then I have no errors at all...
                  Dam' - I suspected as much !
                  50:50 - jumped the wrong way.
                  I'll fix it and release an update...
                    Here's v0.6.7x [please note how it shows in the dialog header as '0.6...' - ALL "v0.6..." files should do this...]
                    It hopefully now fixes the final issue on some MACs, with the 'images' folder needed in the jquery/ui/js etc in the css folder [it does a 'tidyup' and removes any incorrectly located images subfolder automatically when it first loads]...
                    • KrisidiousK Offline
                      Krisidious
                      Thanks a lot for squaring this thing up Tig. It's nice to have it back in the stable.
                      By: Kristoff Rand
                      • cheddaC Offline
                        chedda
                        Yes thanks for your work on this. I can launch the dialog window in new simple files. But for some reason i cannot launch this in existing model files. skp 2014 mac osx 10.9.5 Perhaps it is conflicting with the maxwell plugin ?
                        Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                          maxosmedia
                          Does not work properly with SU 2015 (Mac OS X 10.9.5) — makes only one branch, no leaves. With SU 2014 everything is ok
                          • OxerO Offline
                            Oxer
                            For me it works fine on SU2014/15 & OSX 10.9.5, remember the keys on Mac:
                            Start grow ivy -->Click
                            To make grow ivy to the mouse position-->CMD +Click
                            Make leafs -->ALT+Click
                            Finish the ivy --> SHIFT+Click
                            Reset the ivy--> i key
                              maxosmedia
                              • cheddaC Offline
                                chedda
                                For me it grows and works fine in new files. If i try and open a previous project file i can't get the dialog window to open. It seems to stall.
                                  MalyJacek
                                  I see response to my request to add the ability to choose the leaves.
                                  In the summer I started doing sets of components for the various plants.
                                  They are in varying degrees of completion. https://dl.dropboxusercontent.com/u/32445396/ivyleaf_pasthenocissus.zip
                                  Here is a package for "wild vine" (Parthenocissus) is not 100% like I wanted but one of the curiosities that I wanted to enter. Namely, they are leaves added on two layers of autumn (jesień) and summer (lato) allowing you to quickly change the color by switching layer.
                                  In the future, if you have enough creative inspiration and I will try to finish the remaining sets I am working on and share them.
                                  Sorry for the grammatical errors have not practiced my English for a long long time
                                    MalyJacek
                                    Great that you were able to add choices of leaves which I asked about.
                                    I made a set of leaves for "wild vine" (I do not know the name in English in quotes I gave direct translation of common name in Polish ) in Latin it is Parthenocissus. Characterized by the fact that in the summer the leaves are green but autumn color change to dark red and do not fall for a long time because of that I wanted to add it to the model and more or less succeeded. Leaf models are double on two separate layers thanks to which switching between one and the other can changed season. 😄
                                    In the future, if I have enough creative inspiration to finish the remaining sets for other plants I will also share them.
                                    Sorry for language mistakes I have not practiced writing in English for a long time
                                      Krisidious
                                      Your English is just fine MalyJacek... Really nice contribution.
                                      By: Kristoff Rand
                                      • jujuJ Offline
                                        juju
                                        Would all of these contributions be collected and added to the SketchUp Ivy install (download) or would one have to do it yourself? It would be really neat if it could be incorporated.
                                          driven
                                          working on both new and old models here, Yosemite with v15 SU
                                          • N Offline
                                            nalibo007
                                            please i need help..mine is not appearing under plugins and i have pasted it exactly in the plugins folder. iam currently using sketch up pro 2013.....a help wii be appreciated.
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 32 / 37
