    Hoverbike test
    19 Posts 9 Posters 1.4k Views 9 Watching
    • jeff hammondJ Offline
      cool. curious to see what you come up with.
      • Bryan KB Offline
        Thanks Jeff. Still WIP.
        • Mike AmosM Online
          Cool, I'll take two please.
          • Bryan KB Offline
            Thanks Mike. πŸ˜„
            • Mariyan-HristovM Offline
              Mariyan-Hristov
              Great job ! πŸ˜„
              • Bryan KB Offline
                @mariyan-hristov said:
                Great job ! πŸ˜„
                Thanks Mariyan-Hristov!
                  Tron revival! β˜€
                  • Bryan KB Offline
                    Thanks pilou!
                    This is the final update with the reworked landing gear. I am also going to try an animation of this scene and then a studio render.
                    I will send the model to anyone who would like to render it. Just PM me.
                    • ken28875K Offline
                      ken28875
                      Very cool, Brian. πŸ‘ πŸ‘
                      One order of General Tso's Chicken, to go, please. πŸ˜‰ πŸ˜„
                      A couple of suggestions if I may:
                      1- The fog/atmospheric perspective: the effect of the fog is stronger in the distance/background and less as you get closer to the foreground. The corner of the building and the ground right under the Hoverbike as well as the shadow of the hoverbike should be darker.
                      2- The beam light: if this is the style of render you want, then disregard my comment. But if you are interested in rendering a more realistic effect, I would suggest the edges to be softer and the light should fade as it gets farther away.
                      Photoshop tips:
                      • Use a mask layer to make fog/light beam fade. Click on the "Add layer mask" next to fx in the Layers window. Use Gradient Tool or Brush to add black and dark grey in the areas where you want the fade effect.
                      • To make edges of light beam softer, create the shape of your beam with the Polygonal Lasso Tool and go to Select -> Modify -> Feather. Play around with the numbers to see what works best. Use the technique above to make it fade.
                      Google "beam light" and "fog" or "atmospheric perspective" to see examples, and there are tons of them online.
                      Hope this helps. Keep it up!
                      Have a great weekend!
                      _KN
                      Follow Your Dreams.
                      • Bryan KB Offline
                        Thanks Ken. All great suggestions and you are exactly right about the lighting and atmospherics. πŸ‘
                        What you see right now was all done in SketchUp. I was testing the limits of SU. Here's what I did:
                        • The background is a watermark. WM is set as "background" and not "overlay"
                        • the fog isn't really fog, it's just the blend slider on the WM setting. Fog doesn't work with watermarks.
                        • The WM is what makes the bike shadow "off"
                        • the light beam is a rather dodgy square cone with transparent material πŸ˜†
                        • the shadows really don't match quite right with the background due to SU's lighting limitations (I tried to pick a picture that was somewhat ambiguous for this reason)
                        So yes, it definitely needs more work and I will eventually make the changes. πŸ‘ This is my first experiment with backgrounds in SU. My first tries always look a little wonky. πŸ˜†
                        Again, thanks Ken. That is a very clear step by step process and I will have to try it. I have some other ideas as well that fit with the animation.
